Clear turn signal lens preview |
TonyAKAVW |
Jan 13 2007, 05:25 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Attached thumbnail(s) Attached image(s) |
bondo |
Jan 13 2007, 05:43 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Neato!
Aaron Cox |
Jan 13 2007, 05:53 PM
hmmmm cool.
JPB |
Jan 13 2007, 06:24 PM
The Crimson Rocket smiles in your general direction. Group: Members Posts: 2,927 Joined: 12-November 05 From: Tapmahamock, Va. Member No.: 5,107 |
Now that is very nice (IMG:style_emoticons/default/smilie_pokal.gif)
TonyAKAVW |
Jan 13 2007, 07:00 PM
A pair of these will be on their way to Felix shortly for installation and testing with the HID headlights. They are made of acrylic and should withstand heat and UV.
GWN7 |
Jan 13 2007, 07:10 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
They look very nice Tony....any problems with Customs?
TonyAKAVW |
Jan 13 2007, 07:23 PM
She only brought in 6 lenses, none of which will be sold, so they are considered samples, she got through okay, though they did ask her about them. Probably a good thing she didn't ahve 200 (IMG:style_emoticons/default/smile.gif)
neo914-6 |
Jan 14 2007, 09:08 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
A pair of these will be on their way to Felix shortly for installation and testing with the HID headlights. They are made of acrylic and should withstand heat and UV. (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/boldblue.gif) (IMG:style_emoticons/default/drooley.gif) |
TonyAKAVW |
Jan 14 2007, 11:21 PM
Big thanks to T H O M A S today who helped me blast a couple lenses. The completely fogged lens will make a nice replacement for a regular turn signal lens, and the partially fogged will be good for a euro style turn signal. Next I'm going to try dipping these in amber turn signal dye.
The euro-blasted lens is off a bit. The unblasted part is too big and at a little bit of an angle. I think a blasting jig is in order. -Tony Attached image(s) |
TonyAKAVW |
Jan 14 2007, 11:23 PM
I set up one of the fogged lenses with a set of LEDs. The top portion is illuminated by an array of superbright amber LEDs. The bottom is illuminated by a lensed 5 watt Luxeon Star LED (brightest LED made).
The fogging of the lens does a good job of keeping the elements hidden. Attached image(s) |
Aaron Cox |
Jan 14 2007, 11:49 PM
oh dude... schwing...
im in for a set of euroblasters if you can get the dye thing done! hell i might even be interested in just beadblasted finish! kudos for new products dude... |
nocones |
Jan 15 2007, 12:03 AM
Sportscar lunatic Group: Members Posts: 428 Joined: 17-June 04 From: Santa Rosa, CA Member No.: 2,220 |
Definitely looking forward to these!
KaptKaos |
Jan 15 2007, 12:52 AM
Family Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
Next I'm going to try dipping these in amber turn signal dye. 2 questions: 1) what is this amber turn signal dye of which you speak? Does it work on glass? 2) WTF is that sign behind the pix of the lenses?!?!?! That some EE humor or something? Nice looking lenses T. I'm down for a set too. |
mudfoot76 |
Jan 15 2007, 07:52 AM
Currently teenerless :-( Group: Members Posts: 946 Joined: 18-March 04 From: Carmel, IN Member No.: 1,814 Region Association: None |
oh dude... schwing... (IMG:style_emoticons/default/agree.gif) Those look terrific! How far will that Luxeon throw light? |
TonyAKAVW |
Jan 15 2007, 12:13 PM
Kapt.: 1) I think its just going to be transparent amber paint, maybe with a clearcoat depending on how well it holds up.
2) That sign is no joke, its a real metal sign and says "WARNING HIGH VOLTAGE DEATH ON CONTACT WITH ANTENNA." Bondo found it at a junkyard that sells a lot of commercial and military surplus stuff. Geoff: Not sure how far the Luxeon will throw light. The lens that I have on it produces an oval pattern similar to a headlight. 5 watts of white LED light is really quite a bit, especially with the high color temperature. I doubt it would do much good as a driving light or fog light, but its defintiely a LOT more visible than a euro incandescent bulb. An array of 10 or so could be put in each turn signal bucket, for headlamp use, but at $23 each, that would be expensive. Also, at the full 5 watts output power they are only rated for ~500 hours of life before they start dropping in light output. There are other brands I'm looking at which have longer lifetimes. I'm waiting for a sample from Cree of their latest super high output white LED. |
r_towle |
Jan 16 2007, 01:47 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
can you show these at night from about 30 feet away???
Rich |
TonyAKAVW |
Jan 16 2007, 01:53 PM
Not yet... I'm working on the driver electronics for these LEDs still. The setup in the pictures uses lab power supplies, which I can't easily take outside. (rack mounted).
I'll see if I can hook up some resistors and mount them somehow. The light output from these LEDs is way more than the stock bulbs. -Tony |
r_towle |
Jan 16 2007, 01:56 PM
What i would really love to see is the rear reflector with LED's behind it making it a third brake light...that would be cool
Rich |
markb |
Jan 16 2007, 02:40 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
What i would really love to see is the rear reflector with LED's behind it making it a third brake light...that would be cool Rich (IMG:style_emoticons/default/agree.gif) Tony, I have a broken rear reflector here you can have for testing. |
seanery |
Jan 16 2007, 02:45 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
the frosted appear to be very nice! the euro amber LED setup rocks!
Lo-Fi Version | Time is now: 26th June 2024 - 04:48 AM |
