spunone |
Senior Member ![]() ![]() ![]() Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California ![]() |
Replaced the Master Cyl last nite why is there (IMG:style_emoticons/default/confused24.gif) two connectors and only one male connector on the Master cyl. And I think its the brown wire with the white stripe you use to plug in whats the other brown only wire a ground??
2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
The old MC's had to be grounded through a wire (solid brown)...New style grounds through the case so you only need the Brown/White...Cut or tape back the solid Brown...You don't need it...
2-OH! |
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
yes, just leave the ground disconnected.
spunone |
Great Thanks
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,912 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
Another question answered by the Tech Tips 700! The early master cylinder switch has two connections to trigger the brake warning light, the late cars have one, the ground for that switch being through the master cylinder. The nice thing about the later switch is that is has an external reset button hidden under the little rubber boot!
sean_v8_914 |
Chingon 601 ![]() ![]() ![]() ![]() Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 ![]() |
Hi Doc. I like your 700 914 tips book...where is that thing
Lo-Fi Version | Time is now: 26th June 2024 - 12:56 AM |
