My First 914 FIRE, Now I'm looking for a new wiring harness |
tracks914 |
Feb 1 2007, 09:46 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
Car is on the rotiserrie. The only thing I left on the car was the wiring harness and the fuse panel. The rear wires were all bundled up nicely in a bag in the engine compartment. (IMG:style_emoticons/default/devil.gif)
I was welding up a patch in the fire wall from the drivers compartment side, and I guess some sparks flew into the engine compartment and started the bag on fire. (IMG:style_emoticons/default/new_shocked.gif) By the time I noticed it was on fire and put it out I had some big clumps of plastic and the fused together wire was toast!! Anyone got a good used wiring harness....cheap??? |
r_towle |
Feb 1 2007, 09:57 PM
Custom Member Group: Members Posts: 24,645 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
possibly from an Ljet, 74
Rich |
McMark |
Feb 1 2007, 10:05 PM
I think he needs a whole car harness, Mike. (IMG:style_emoticons/default/wink.gif)
davep |
Feb 2 2007, 08:41 AM
914 Historian Group: Benefactors Posts: 5,213 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I may have one. Did have lots at one time. PM me if you want to work out something.
markb |
Feb 2 2007, 08:44 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
You could also check with hwgunner. He's stripping a 76.
dr914@autoatlanta.com |
Feb 2 2007, 09:30 AM
914 Guru Group: Members Posts: 8,102 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Car is on the rotiserrie. The only thing I left on the car was the wiring harness and the fuse panel. The rear wires were all bundled up nicely in a bag in the engine compartment. (IMG:style_emoticons/default/devil.gif) I was welding up a patch in the fire wall from the drivers compartment side, and I guess some sparks flew into the engine compartment and started the bag on fire. (IMG:style_emoticons/default/new_shocked.gif) By the time I noticed it was on fire and put it out I had some big clumps of plastic and the fused together wire was toast!! Anyone got a good used wiring harness....cheap??? If you have a 73 you need a 73 harness. They are unique. If you have a 70-71 the harnesses interchange. If you have a 74 you need a 74 it is unique. If you have a 75-76 they interchange. |
Jeffs9146 |
Feb 2 2007, 11:34 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE I was welding up a patch in the fire wall from the drivers compartment side, and I guess some sparks flew into the engine compartment and started the bag on fire. ............(IMG:style_emoticons/default/blowup.gif) (IMG:style_emoticons/default/shocked[1].gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) JK Jeff |
SirAndy |
Feb 2 2007, 02:07 PM
Resident German Group: Admin Posts: 41,894 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
If you have a 73 you need a 73 harness. They are unique. If you have a 70-71 the harnesses interchange. If you have a 74 you need a 74 it is unique. If you have a 75-76 they interchange. (IMG:style_emoticons/default/agree.gif) i put a '74 harness in my '70 car and it was a lot of work to get it all right. even needed some grinding and welding ... save yourself a lot of headache and get a complete harness from the same year. (IMG:style_emoticons/default/smile.gif) Andy |
tracks914 |
Feb 2 2007, 04:06 PM
I'm not too worried about the engine wiring because I want to go with a 6 or a Raby 4 with carbs. Even if I got one from under the dash to the rear as long as I get all the power, lighting, charging, reverse I think I can make it work from there.
Is there a difference between the 73 1.7 and 2.0 harness?Early 73 and late 73? |
GWN7 |
Feb 3 2007, 01:37 PM
King of Road Trips Group: Members Posts: 6,280 Joined: 31-December 02 From: Winnipeg, MB, Canada Member No.: 56 Region Association: Northstar Region |
I've got one out of a 72...not knowing any better at the time I pulled it out by cutting it in 1/2 in the middle of the tunnel.
The tail section should be the same on all years? You can have it, if it works to splice into your existing harness if you can't find a compleat one. It's in my shed so I hope your not in a rush as the shed is burried under snow right now. |
tracks914 |
Feb 3 2007, 01:52 PM
I'll PM you.
Since all I think I need is for everything but the FI it just might work. Snow? You have snow? We have about 12" in my yard right now. We can still drive anywhere by 4x4 and don't need a snowmachine yet!!! |
orange914 |
Feb 9 2007, 06:26 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
ive got a complete 71 still in the car im parting. let me know if your still l@@king
tracks914 |
Nov 18 2007, 04:03 PM
If I put a complete 71 in my car will the 1.7 FI still work?
So far the only differences I see (going to the rear) are: console gauges wiring is not there RR Def in not there seat belt warning lights are not there. From the fuse panel forward shouldn't they all be the same? If change the whole thing out, what troubles am I looking forward to?? |
SirAndy |
Nov 18 2007, 04:11 PM
If I put a complete 71 in my car will the 1.7 FI still work? '71 in a '73 car won't work unless you do some major modifications, like a '71 steering column etc. your best bet is to get a complete harness for your year. call EASY and ask john or call HPH and ask rich ... (IMG:style_emoticons/default/bye1.gif) Andy EASY HPH |
tracks914 |
Nov 18 2007, 08:01 PM
ClayPerrine |
Nov 18 2007, 09:13 PM
Life's been good to me so far..... Group: Admin Posts: 15,902 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If I put a complete 71 in my car will the 1.7 FI still work? '71 in a '73 car won't work unless you do some major modifications, like a '71 steering column etc. So can I splice the rear section into the '73 harness? Whatever you do.... DO NOT SPLICE THE HARNESS TOGETHER You will end up with problems that will take you months to sort out. I would follow the advice of most of the members here.. get a complete harness from a car of the same year. You will have much better luck by doing that. Andy wrote an excellent article on how to replace the harness. Pull it now and finish the welding. Then put the replacement complete harness in the car. |
tracks914 |
Nov 18 2007, 09:25 PM
Pull it now and finish the welding. Then put the replacement complete harness in the car. Car is welded, painted and re-assembly is in progress. I was just hoping the colour coding on the harnesses was the same from year to year. Splicing and soldering wires is easy as long as blue goes to blue and green to green!!!! (IMG:style_emoticons/default/w00t.gif) |
SirAndy |
Nov 19 2007, 11:31 AM
I was just hoping the colour coding on the harnesses was the same from year to year. Splicing and soldering wires is easy as long as blue goes to blue and green to green!!!! (IMG:style_emoticons/default/w00t.gif) wires are different over the years. even in the rear .... please don't splice ... i got a complete harness in near perfect shape from EASY for $100. they even took it out of the donor car for me, didn't have to get my hands dirty ... look for the classic thread on how to remove & install a main harness ... (IMG:style_emoticons/default/shades.gif) Andy |
orange914 |
Nov 19 2007, 05:10 PM
tracks914 |
Nov 19 2007, 05:51 PM
i think i still have that 71 uncut body harness $100 shipped Thanks but I have a great '71 but I need a good '73. BTW Andy What if I was switching to carbs?? I was thinking of going with a 2256? Raby engine in this car and don't know if I really need all those wires?????? |
Lo-Fi Version | Time is now: 24th November 2024 - 10:43 PM |
