Trunk Metal Rollers, Rear Tension Bar |
martinef1963 |
Mar 1 2007, 07:57 PM
The Saga Continues... Group: Members Posts: 320 Joined: 9-November 04 From: Miami, FL, USA Member No.: 3,080 Region Association: South East States |
Yep - I did it! (IMG:style_emoticons/default/biggrin.gif) I managed to let the tension bar slip off of the rear hood hinge...
How does an average bear get the bar back in place without having to break out a jack hammer on the darn thing? (IMG:style_emoticons/default/dry.gif) thanks, |
Dave_Darling |
Mar 1 2007, 08:14 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
A long metal bar with a slot cut into the side of it near the end.
Some people have sliced into the side of the hole in the handle end of a crescent wrench. I have used a box-end wrench with no slice in the side. I don't recommend it, it slips off way too easily. Some have mentioned slipping a deep well 1/4" socket over the end of the arm, and using an extension as the lever. --DD |
Rand |
Mar 1 2007, 08:21 PM
This is the point where you consider gas shocks instead. (IMG:style_emoticons/default/smile.gif)
Kidding... I'm sure you have. But I'm sure happy I went that route. Camp914 has a great kit ready to bolt on. I pulled some off a hatchback at a pull-a-part wrecking yard and fabbed my own brackets. |
rhodyguy |
Mar 2 2007, 09:06 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
8 or 9mm 1/4 drive deep well socket slipped over the end of the spring and an extension. open the rear hood to reduce the spring pressure.
k |
Lo-Fi Version | Time is now: 25th June 2024 - 06:03 PM |
