burton73 |
burton73 ![]() ![]() ![]() ![]() Group: Members Posts: 3,567 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California ![]() ![]() |
What Mods. are needed to put a 3.2 in a 914-6 car? Can you bolt up to a 901 box? Does the injection clear the car without cutting?
Bob |
736conver |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,117 Joined: 25-May 03 From: SE Wisconsin Member No.: 736 Region Association: None ![]() |
What Mods. are needed to put a 3.2 in a 914-6 car? Can you bolt up to a 901 box? Does the injection clear the car without cutting? Bob Yes you can mount it to a 901/914 box. Injection clears but you may have to either turn the manifold 180 or make a custom tube for the air cleaner. I just used a extension and a 90 degree bend for the air cleaner. You will also have to cut a notch in the transmission for the sensors. Check out my blog and you can see the cut. Besides that its just like installing any other six. |
736conver |
I should also add I removed my engine lid torsion bars as they got in the way when working with the fuel lines on the back of the manifold.
Heeltoe914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,135 Joined: 31-January 06 From: Tujunga Calif, Member No.: 5,506 ![]() |
You are in LA come up to Tujunga sometime and I will show you the ends and outs on two 3.2 cars. Very easy on a 6.
burton73 |
Thank you for your offer. I am waiting for an Email to do this deal. Have you put a Steve Wong chip in those? I am not on commission but his chip made a world of difference on my 86 Carrera. A huge difference and I still passed smog not that it matters on the 914s.
Bob |
dflesburg |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None ![]() |
Its easy.
My brother only took about 9 months to do his... I on the other hand, am working on year 15. If I can get it running before June, I can say, it took 14 years... Good Luck! |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Hey,
I started in Feb 06 and had it running in July 06. Check my BLOG. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/driving.gif) |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
You need a special flywheel that fits the 3.2 engine (nine bolts) and also fits into the 901 gearbox. KEP, I think, sells those. You need the version that has the teeth for the crank position sensor of the DME. You may (not sure) need to fake up a bracket for the sensor.
Keep in mind that the 901 is somewhat marginal in durability on a 3.2 engine. You'll have to be somewhat careful with it, and you may find it requiring help sooner than if you used a little motor with it. --DD |
xitspd |
Technology and Tradition 3.6 and 914-6 ![]() ![]() ![]() Group: Members Posts: 1,305 Joined: 17-November 04 From: Foothills of Mt. San Jacinto, CA Member No.: 3,136 ![]() |
I agree with Dave. I use a 901 with 914-6 3.6(traditional, original equipment). The 901 is heavily modified and it still see's the Doctor at least once a year.
Dan Attached image(s) ![]() ![]() |
John |
Not the flywheel, you need a special pressure plate and clutch disc.
KEP does sell what you need. My 3.2 in my street car is using the 3.2 flywheel and a KEP perssure plate and disc. The 914-6 other parts should transfer over to the 3.2 fairly easily. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:20 PM |
