Dizzy drive off 180*, will it affect FI points? |
jasons |
Mar 11 2007, 08:21 AM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
I am convinced the dizzy drive in my car is off 180*. Motor is at TDC, verified by the valves, the timing mark on the fan, and flashlight in the #1 spark plug hole.
Currently the rotor points away from the driver and the only way the Dizzy fits in the car is with the back of the rotor pointed at the notch in the dizzy. I don't mind leaving it this way, but does anyone know if it will affect the synchronization of the FI points? |
Bleyseng |
Mar 11 2007, 08:29 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
It will run like that as the triggers fire every 180' of crank rotation. I will it run better if you flip the dizzy drive back to stock.
jasons |
Mar 11 2007, 08:55 AM
Why would it run better flipped back? It seems to me either it would work or not work. I'm just curious what the difference is.
Gint |
Mar 11 2007, 09:38 AM
Mike Ginter Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
It will run the same either way. I'd probably fix it IIWM also, but you don't have to.
Allan |
Mar 11 2007, 09:44 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
It will run the same either way. I'd probably fix it IIWM also, but you don't have to. (IMG:style_emoticons/default/agree.gif) I ended up installing my dizzy 180 out while trouble shooting (fuel problem after all (IMG:style_emoticons/default/dry.gif) ) and it ran great. |
jasons |
Mar 11 2007, 09:46 AM
Well, I successfully re-indexed the drive either way. It was kind of bugging me that it wasn't right. But, I didn't want to F- with it, and drop that washer in. I used a 7/32 allen socket on the end of a nut driver which fit just right, to pull and turn the drive.
Bleyseng |
Mar 11 2007, 12:34 PM
Very slight it is....
Lo-Fi Version | Time is now: 25th June 2024 - 12:11 AM |
