orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
yeah i have the bar, i have the tank out and am doing steel lines now. i thought there where dimples to just pop the holes in... wrong. (IMG:style_emoticons/default/chair.gif) anyone have acess to a downloadable template or good pictures? (IMG:style_emoticons/default/sawzall-smiley.gif)
thanks |
Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Dont you have the mounts that are on the bar?
If yes, just put those in the middle of the factory Indent. YES there is a spot for it to be drilled from the factory, but you'll need those hole markings from that mount. ahh shoot... Here http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm |
orange914 |
Dont you have the mounts that are on the bar? If yes, just put those in the middle of the factory Indent. YES there is a spot for it to be drilled from the factory, but you'll need those hole markings from that mount. ahh shoot... Here http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm hey andrew, do you think you could come over wednesday or thrursday? your expertise would really be a huge help! (IMG:style_emoticons/default/poke.gif) |
Andyrew |
pm sent.
rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,002 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
orange914 |
Dont you have the mounts that are on the bar? If yes, just put those in the middle of the factory Indent. YES there is a spot for it to be drilled from the factory, but you'll need those hole markings from that mount. ahh shoot... Here http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm got it in today! (IMG:style_emoticons/default/clap56.gif) (IMG:style_emoticons/default/thumb3d.gif) ![]() |
orange914 |
Andyrew |
I told you its easy!!
Now what about the U tab? |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
Are you going to weld those in? I would suggest it as there is a lot of stress there. If you do any hard driving, they could move and tear the metal around it. When I do mine I weld them in and on the one I am doing now, I am welding in the Engman stiffening kit he makes just for that area.
Attached thumbnail(s) ![]() |
Andyrew |
He doesnt do much hard driving, I built those plates out of thin 16 Gua metal.
He's running stock tires, stock suspension, ect.. I think he'll be fine.. But if he does start running sticky tires and autoxing I agree he should strengthen that area. |
orange914 |
skline |
The U tabs are what the drop link connects to mounted on the control arm. See picture below.
Attached image(s) ![]() |
orange914 |
The U tabs are what the drop link connects to mounted on the control arm. See picture below. plan on bolting those on today (has existing tabs on lower arms). gotta run the power up front to the relocated fuel pump also before setting the tank back in. this started as plastic tunnel fuel line conversion and we went ahead and moved pump and drilled for the sway bar while it is apart. i also changed trans fluid with redline GL5 synthetic, well see if there is any difference |
skline |
If they are already there, you are set. Mine has a Carerra front end with an underbody bar mount on the control arms I need to cut off and change to the old through the body type. Which is why I have the U tabs here waiting to go. It sounds like you are good to go. More pictures would be nice (IMG:style_emoticons/default/smile.gif)
orange914 |
If they are already there, you are set. Mine has a Carerra front end with an underbody bar mount on the control arms I need to cut off and change to the old through the body type. Which is why I have the U tabs here waiting to go. It sounds like you are good to go. More pictures would be nice (IMG:style_emoticons/default/smile.gif) i'll be making an article with more detail later as i have time. (IMG:style_emoticons/default/beerchug.gif) ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
orange914 |
![]() ![]() ![]() ![]() ![]() oh yeah... steel fuel lines & front fuel pump relocation TOO! i'll post later if it'll help others thru it. not finished yet but it's coming along (IMG:style_emoticons/default/alfred.gif) |
Lo-Fi Version | Time is now: 1st July 2024 - 06:17 AM |
