shaggy |
mechanic/welder/fabricator ![]() ![]() ![]() Group: Members Posts: 702 Joined: 26-September 05 From: Gilbert, AZ Member No.: 4,869 Region Association: None ![]() |
i have the sender wire through the tunnel
and i have the 12v switch power(light) i have the grounds i just need to get the 12v hot constant. what gauge would i get that from? tach or fuel? and what terminal? thanks -jim |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
Either. I believe it is a red wire with a white stripe.
shaggy |
are you sure enough for me to go wire it up? (IMG:style_emoticons/default/biggrin.gif)
thanks for the fast reply. ill go out and wire it as soon as i finish lunch! |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
red w/ white stripe wire indeed is switched +.
if you wired it to a constant +, they would read oil temperature even when the keys are not in the ignition. |
race914 |
73 914-4 ![]() ![]() ![]() Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California ![]() |
If you have the console, use the clock + it is not switched.
Aaron Cox |
If you have the console, use the clock + it is not switched. he has a 72 (in his sig) 73 and later were wired with the center console harness (IMG:style_emoticons/default/smile.gif) |
race914 |
Doh! (IMG:style_emoticons/default/blink.gif)
Good catch Aaron, I didn't read the signature and catch the "72".. |
Aaron Cox |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
i guess it was a 'catch 72' ? how about "Catch 23" ??? http://www.sirandy.com/mp3/GBH_Catch23.mp3 (IMG:style_emoticons/default/aktion035.gif) Andy |
Lo-Fi Version | Time is now: 25th June 2024 - 11:15 PM |
