daveyboybadion |
Member ![]() ![]() Group: Members Posts: 108 Joined: 19-January 06 From: Seattle, WA Member No.: 5,437 Region Association: Pacific Northwest ![]() |
(IMG:style_emoticons/default/WTF.gif) I am in the process of gathering core parts for a 2060 build up of my 1.8 engine. I have sourced 2.0 lt rods and a crank but they are out of the block already. How do I determine if I am buying the actual rods and crank that I need? I'm quessing the rod should measure 71 mm from the big end center to the little end center, but what about the crank? Any casting marks or measurements to indicate the differences between a 1.8 and a 2.0? Thanks for the help...daveyboy
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
No, the rods are NOT 71mm long.
Measure the center of one rod journal to the center of the rod journal on the other side of the crank instead. |
daveyboybadion |
Ok that makes sense, what about identifying the rods?...daveyboy
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
Easy, 66 mm rods have a huge block of steel on the smallend of the rod, 71mm rods don't.
Lo-Fi Version | Time is now: 26th June 2024 - 01:15 AM |
