jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
thanks jim
http://www.pbase.com/jimkelly/image/77494098/original.jpg what is compnent dangling just under coil in pic with vaccum line connected to it?? note i appear to have vaccum advance and vaccum retard vaccums lines |
pbanders |
Senior Member ![]() ![]() ![]() Group: Members Posts: 939 Joined: 11-June 03 From: Phoenix, AZ Member No.: 805 ![]() |
That's your decel valve. You also don't appear to have a flashback trap or hoses from your head vents (normal on a '75?).
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Check the ports on the throttle body. On my '75, one of them was a dummy port and IIRC it was the one you have the vacuum advance tied into.
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
No head vents on '75 - '76.
The Throttle Body is that of a '73 (dual vac pipes for advance/retard). '74 up has a single vac tap. |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
What's with all the water hoses? Is this some trick hybrid cooled secret project ... ?
The Cap'n |
jimkelly |
ok - found the main problem - one fat port on the plenum had no hose to it nor was it plugged - i plugged it and engine now runs fine - took it on a food shopping run with my son - he was impressed that this car has paint and an interior : ))))
also i removed decel valve. more pics of drivers side port hole and passenger side port hole and decel valve before removal. see my blog thanks guys |
jasons |
Jackstand Extraordinaire ![]() ![]() ![]() ![]() Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None ![]() |
What's with all the water hoses? Is this some trick hybrid cooled secret project ... ? The Cap'n (IMG:style_emoticons/default/chairfall.gif) The good Cap'n made a joke! I've seen hoses like that collapse on themselves under vacuum. |
jimkelly |
finding the right ID hose at flaps is hell - guess i will just get full set at pelican parts ??
jim |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
I wouldn't remove the decel valve if I was you.
Lo-Fi Version | Time is now: 25th June 2024 - 08:36 PM |
