rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,102 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i marked the dist housing @ the #1 wire position. for practice i turned the old engine to the point where the flywheel mark is at the top, centered on the case parting line. slack on i&e valves. if i do the same on the new engine, set the dist rotor to the marked line and slide it in, this should get me in the ballpark for spark?
k |
Brando |
BUY MY SPARE KIDNEY!!! ![]() ![]() ![]() ![]() Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California ![]() |
You could have that distributor rotated 270ยบ for all it cares... As long as you're setting your static timing with the engine on TDC #1 and the rotor pointing to the #1 Mark and your wires are in the right order.
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
rhodyguy |
i left the dist clamp on the mallory when i pulled it, so i think getting to tdc on 1 and bolted in everything should be fine for the fire up. thanks guys.
k |
Lo-Fi Version | Time is now: 20th June 2024 - 05:23 AM |
