removing a busted ass cv bolt, argh... more problems. |
mrhurtalot |
Apr 23 2007, 07:43 PM
VRRRRRRROOOOOOOOOM! Group: Members Posts: 323 Joined: 5-October 06 From: Yukon, Oklahoma Member No.: 6,996 |
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
holy begeezus, seems things dont want to work out for me. short vers. cv bolt not a torx driver stripped... (IMG:style_emoticons/default/confused24.gif) SEARS! bolt remover head snapped off. ........ ....... two weeks later still stuck. tried various things, pb blaster, reverse bits, tap die set. drill nothing seems to work. if you are local and you happen to help me maybe you can get some free (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) Attached thumbnail(s) |
Bartlett 914 |
Apr 23 2007, 07:47 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) holy begeezus, seems things dont want to work out for me. short vers. cv bolt not a torx driver stripped... (IMG:style_emoticons/default/confused24.gif) SEARS! bolt remover head snapped off. ........ ....... two weeks later still stuck. tried various things, pb blaster, reverse bits, tap die set. drill nothing seems to work. if you are local and you happen to help me maybe you can get some free (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beerchug.gif) I would grind the head off. Remove the other bolts and the CV joint. The bolt should then screw out. Maybe loctite was used. Heat it and use vise grips if it is stuck. |
rick 918-S |
Apr 23 2007, 07:59 PM
Hey nice rack! -Celette Group: Members Posts: 20,512 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Ya, heat it just a little. Someone may have used locktite. Also you may be able to weld a nut over the end of the fudged head and back it out that way. (don't ask me how I know... (IMG:style_emoticons/default/mad.gif) )
Dave_Darling |
Apr 23 2007, 09:13 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
And it's definitely not a Torx head. You want an "M8 triple square", or "the Bug CV joint socket".
--DD |
mrhurtalot |
Apr 23 2007, 10:39 PM
dave. i know that now. LMAO
MARK! thanks so much. you'd think for a future engineer id have a little more imagination than what i do.... if you are ever near me in oklahoma free case of beer to you. or whatever soda you like best! cv's off trannys out tommorrow afternoon. hopefully be able to drive the car before it gets too hot and i have to fix the A/C! IT NEVER ENDS!!! |
Andyrew |
Apr 24 2007, 12:52 AM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Dang... at this point I would have welded a 3/8 extension on it and busted that nut..
er bolt. |
John |
Apr 24 2007, 12:59 AM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
Like Mark suggested, I would grind it off to get the CV joint off. You could then use a locking type pliers to remove the bolt. if it is still stuck, you can get a real cheap output flange for the trans.
Bartlett 914 |
Apr 24 2007, 08:57 AM
dave. i know that now. LMAO MARK! thanks so much. you'd think for a future engineer id have a little more imagination than what i do.... if you are ever near me in oklahoma free case of beer to you. or whatever soda you like best! cv's off trannys out tommorrow afternoon. hopefully be able to drive the car before it gets too hot and i have to fix the A/C! IT NEVER ENDS!!! Good to hear you got it off. Sometimes these things really kill our enthusiasm. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 09:38 PM |
