rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,113 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
they went on smooth as silk. just need to tighten them down. thanks ya'll (IMG:style_emoticons/default/thumb3d.gif) .
k |
Chris Pincetich |
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California ![]() |
Purely from memory - lets see if I am perma (IMG:style_emoticons/default/smoke.gif)
17 lbs (IMG:style_emoticons/default/beerchug.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Whatever the torque spec is, odds are it'll need to be tighter. I run 'em and do the final tightening while it's hot (and running). The Cap'n
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
I run 'em and do the final tightening while it's hot (and running). The Cap'n On jack stands... (IMG:style_emoticons/default/av-943.gif) |
DanT |
Going back to the Dark Side! ![]() ![]() ![]() ![]() Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None ![]() |
On Tunacan they say 14#s. I set mine to this setting cold during build and will retorque to a slightly higher setting once the motor is warm and the cam is broken in...while the motor is still pretty warm...
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
i asked the same question a long time ago and Jake said 18 ft-lb
Lo-Fi Version | Time is now: 25th June 2024 - 04:47 PM |
