2-OH! |
Senior Member ![]() ![]() ![]() Group: Members Posts: 552 Joined: 17-October 03 From: Santa Clarita, Kalifornication Member No.: 1,253 ![]() |
While I am doin' the winter projects list...
I was making a jumper to go around the seat belt relay under the passenger seat and thought "instead of just connecting these two wires, I could hide a switch to prevent theft." I have read the articles on the tach wire from the coil etc., but this seems much simpler... Need some other thoughts... 2-OH! |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
Do you use the heater lever for the fan ??
I have used the heater lever to control the ground for the fuel pump relay in the past (when the car didnt have a heater fan). b |
2-OH! |
Brad:
Yea, I still use the heater up here...But the main question is do you think that's a good place to splice in the wiring system... 2-OH! |
p914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 518 Joined: 7-September 03 From: Sunny South Florida Member No.: 1,117 Region Association: None ![]() |
If we tell ya where and how, we will have to come and take your car (IMG:style_emoticons/default/ph34r.gif) (IMG:style_emoticons/default/zorro.gif)
2-OH! |
OK,,, but just leave the jackstands...I've become attached to em'...
2-OH! |
pjhaun |
Member ![]() ![]() Group: Members Posts: 370 Joined: 21-August 03 Member No.: 1,055 Region Association: None ![]() |
2-OH:
This is what I did to my 9174 914. It has a red plastic key that I can turn and remove to disconnect the ppwer to the starter. Attached image(s) ![]() |
pjhaun |
Here is another picture.
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
I think I see a seat rail, but can't get my bearings. Where did you put the switch?
sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
It looks like it's next to the passenger side seat belt buckle.
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
behind the seat belt
seanery |
I get it now. We're looking at it from the passenger seat area towards the firewall. Gotcha!
scotty |
The Fun Never Stops ![]() ![]() ![]() Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None ![]() |
Another trick is to use one of those "impact disconnect" collision switches for the fuel pump ground (Ford has one for under $20). Just whack it when you leave and push the reset when you come back.
Lo-Fi Version | Time is now: 20th June 2024 - 11:16 PM |
