wbergtho |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 ![]() |
I have a V-8 converted car...and I thought I'd ask if anyone has any experience with additives or "suppliments" that you might put into the coolant of a water cooled car? I have a modern LS series GM motor in my 914 and the GM factory recommends the Dexcool orange/red coolant in these motors. I have heard a few nightmare stories about Dexcool and have known that the "old school" green Prestone coolant works just fine in an all aluminum motor. My question is specifically this: If I run the old school Prestone, do I need any further additives to minimize the possibility of corrosion or other pitfalls? Any comments and/or experience with different coolants and aluminum motors would be quite helpful. I need a better education on this matter.
Regards, Bill |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Of the "old school" ethylene glycol mixtures, PEAK (formulated by Northern Chemical) was supposedly the best. To the ethylene glycol base, sodium metaborate (ph stabilizer scale control/corrosion inhibitor), wetting agents (make water wetter/keep contaminants in solution), sodium nitrite (corrosion inhibitor), sodium silicate (corrosion inhibitor), and dispersants amongst other things are added. I can see no need for additional "additives".
It should be changed every two years as the heat cycles will eventually break the ethylene glycol into two organic acids. Corrosion proceeds unchecked after that point. Anyway .......... that's what I was taught |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
There are some new waterless coolants that sound very appealing. They're basically 100% glycol. Supposedly they can move more heat than water, stop corrosion, won't boil at any possible engine temp, all without any pressurization of the system. The downside is the price, and ALL the water has to be purged from the system. I guess price isn't really a downside, since the stuff should last forever. I've never tried the stuff, but I intend to.
The best part is that when people say your 914 is water cooled, you can say "no it isn't!" (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 07:53 AM |
