> JWest Shift Kit Install Part 2, the forward shift rod
McMark
post Jun 11 2007, 01:45 AM
914 Freak!
Click here for part 1.
Time to install the forward shift rod section. This is the section that goes inside the car. There is a bit of welding. But this was a pretty easy install.
First we cut the stock forward shift rod just behind the welds. We will be keeping the section on the left which is what attaches to the shifter. We will need to remove the remnants of the outer tube and just keep the insert.
To remove the outer section, we used a lathe because one was available. You can also carefully grind off the welds, which would be just as easy.
James gives a measurement for the total length of the shift rod (34 3/4" IIRC?). So this is what it will look like. I measured the rod and marked where it needed to be. The mark let me easily see if something got bumped out of place just before welding.
The bushing is pretty easy to install. We just held the bushing in place, marked where to drill and made some holes. A quick paint and then bolt up the bushing (there is a specific way to orient the bushing). This was an early chassis which doesn't have the circle on the firewall (it's got a big oval). So we ground that all off and used an extra piece of rubber behind the bushing to completely seal it to the body. And finally, I hopped in the car with an extendable magnet and used that to feed the bolts through the holes. Then Andy grabbed them from the engine bay so I could detach the magnet. It worked great. Then I used a long 1/4" extension to hold the bolts in place while Andy slipped the bushing over the bolts and threaded on the nuts.
Here is the shift rod TIG welded together. A quick coat of paint to protect it and then we slid it into place.
We attached the new rod to the shifter so that when you pull back as far as it will go, the shift rod just sticks out past the bushing. Then we put the univeral joint onto the end.
There is one more part to go. The rear shift rod section! (IMG:style_emoticons/default/wink.gif) Stay tuned later this week.
Replies(1 - 7)
post Jun 11 2007, 02:41 AM
Resident German
a little bit of grinding involved because this is an early chassis, but otherwise, a quick and easy install ...
(IMG:style_emoticons/default/cool_shades.gif) Andy
BKLA
post Nov 24 2007, 11:08 AM
Really old member
Are you going to finish this Thread?!? (IMG:style_emoticons/default/biggrin.gif) I have been waiting now for months!!!!
Did you have to fabricate the center section of rod?
How about pics of it once it was installed? Your opinion on how it works?
Great Job ANdy and Mark!
scottb
post Nov 24 2007, 11:41 AM
who wants a PEZ?!
ooooohh!!
i didn't know that i needed this until just a minute ago!
will be dropping the old and putting in the new over winter so this would be perfect to compliment the new plant.
i too eagerly look forward to completion of this series....
cheers!!
post Nov 24 2007, 03:25 PM
Resident German
there's more about the install in my conversion thread. see link in my signature ...
(IMG:style_emoticons/default/bye1.gif) Andy
Jeff Hail
post Nov 24 2007, 10:15 PM
QUOTE(McMark @ Jun 10 2007, 11:45 PM) *
Damn nice welds on the rod. Good write up.
ConeDodger
post Nov 25 2007, 12:20 AM
Apex killer!
QUOTE(Jeff Hail @ Nov 24 2007, 08:15 PM) *
It's JB Weld. Mark uses it for everything... (IMG:style_emoticons/default/shades.gif) (IMG:style_emoticons/default/av-943.gif) Sorry, Not true but Mark will appreciate it.
BKLA
post Oct 26 2011, 11:25 PM
Really old member
Just wanted to add that the length of the front bar is 32 3/4" not 34 3/4". I looked it up here hoping that the number was correct as I purchased one of the remaining partial kits, and I knew this was a "keeper" thread.
34 3/4" was too long, so I emailed JWest. 32 3/4" fits perfectly.
- Lo-Fi Version Time is now: 24th November 2024 - 05:27 PM
