no turn signals and brake lights, where do I start? |
jfort |
Jun 17 2007, 11:33 AM
Senior Member Group: Members Posts: 1,144 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest |
to try to solve no turn signal problem, I replaced light switch and flasher relay, checked fuses, cleaned all connections and put in new bulbs, cleaned but did not replace turn signal switch. now i realize i have no brake lights either. all other lights and emergency flashers work. i think those two circuits are not getting power. i have to find my color wiring diagram, but in the meantime, can someone tell me where to start? they say, "check grounds." i have and know how to use a meter, but i don't know how to check grounds. help
904svo |
Jun 17 2007, 12:14 PM
904SVO Group: Members Posts: 1,124 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Check fuse#9 for power (12 volts both sides) this runs to the brake light switch
and then to the brake lights. You may have to clean the connection on fuse #9. |
seejay5 |
Newbie Group: Members Posts: 13 Joined: 12-June 07 From: Centreville, MD Member No.: 7,808 |
Fawk it, use hand signals.
jfort |
Jun 18 2007, 07:53 PM
thanks, 904svo. i thought i had checked fuses. but, sure enough, #9 was burnt. i had run a wire from the right rear to a middle LED brake light. it rubbed through and was touching the body. fixed not only the brake lights, but also the turn signals. IM SO HAPPY!
904svo |
Jun 18 2007, 08:36 PM
thanks, 904svo. i thought i had checked fuses. but, sure enough, #9 was burnt. i had run a wire from the right rear to a middle LED brake light. it rubbed through and was touching the body. fixed not only the brake lights, but also the turn signals. IM SO HAPPY! Glad you found your problem. |
Lo-Fi Version | Time is now: 5th January 2025 - 01:15 AM |
