Bogaat |
Member ![]() ![]() Group: Members Posts: 195 Joined: 8-January 07 From: Charleston, SC Member No.: 7,436 ![]() |
Two of the wheels do not have VW symbols and look a little different on the back. Are they factory? (IMG:style_emoticons/default/sad.gif)
Bogaat |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Actually I think that they are both repro's.
IIRC, real fuch's have the fox symbol stamped on them. |
Bogaat |
G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
1st they look good (IMG:style_emoticons/default/beerchug.gif)
I'm not an expert, and I've only had my hands on 22 2ltr wheels but none of them look like the second pic all of them match the first. was there 2 different part #'s on Fuchs? i will check PET for this info and get back to you |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
all factory (IMG:style_emoticons/default/smile.gif)
G e o r g e |
Thy wheel master has spoken (IMG:style_emoticons/default/pray.gif) I will save the 10 min searching (IMG:style_emoticons/default/piratenanner.gif) |
Bogaat |
Allan |
Whew...ok, next question. The two older wheels appear to have had the wrong lugs used with them at some point. They definitely cut into the seats. Should I be overly concerned? ![]() No. Just use the correct lug nuts next time. If they torque down well it should be gud... Sorry on the mis-dentification earlier.... |
Lo-Fi Version | Time is now: 25th June 2024 - 12:53 AM |
