Dr. Roger |
A bat out of hell. ![]() ![]() ![]() ![]() Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California ![]() |
I was getting consistent missing and a couple of fouled plugs even after a complete ignition system inspection and plug change.
Pertronix working perfectly. Hot coil working perfectly. New cap, rotor, wires, and plugs. New Edelbrock 750cfm mechanical secondary carb. Settings "close enough". Mallory dizzy. Recurved. (huge difference, I might ad) Fresh rings/heads. quick edit: no air cleaner. I won't let myself live this one down for years.... (IMG:style_emoticons/default/blink.gif) Any guesses as to what was causing the fouled plugs? (IMG:style_emoticons/default/idea.gif) |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
(IMG:style_emoticons/default/confused24.gif) Rag in the carb?
Joe Ricard |
CUMONIWANNARACEU ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 ![]() |
Loose jet?
Johny Blackstain |
Walnut Elite Stratocaster player ![]() ![]() ![]() ![]() Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region ![]() ![]() |
MJHanna |
Does this 911 make my butt look big? ![]() ![]() ![]() Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 ![]() |
it's a V8 (IMG:style_emoticons/default/poke.gif)
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
loose nut behind the wheel (IMG:style_emoticons/default/confused24.gif)
AZ914 |
914 Dumbass ![]() ![]() ![]() Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region ![]() |
I don't want to guess, just fuchin tell me.
(IMG:style_emoticons/default/smile.gif) |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Accidentally filled it up with deisel?
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
I was getting consistent missing and a couple of fouled plugs even after a complete ignition system inspection and plug change. Pertronix working perfectly. Hot coil working perfectly. New cap, rotor, wires, and plugs. New Edelbrock 750cfm mechanical secondary carb. Settings "close enough". Mallory dizzy. Recurved. (huge difference, I might ad) Fresh rings/heads. quick edit: no air cleaner. I won't let myself live this one down for years.... (IMG:style_emoticons/default/blink.gif) Any guesses as to what was causing the fouled plugs? (IMG:style_emoticons/default/idea.gif) hydraulic lifters weren't lashed right on the exhaust on those 2 cylinders? |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
1.) You installed the rings upside down.
2.) Plug gap was to small.a 3.) It's a V8. 4.) Your hand slipped off whist googling the Ladies calendar. |
So.Cal.914 |
Is this what you would call a dramatic pause? Give it up already.
Dr. Roger |
TROY!
you called it. (IMG:style_emoticons/default/clap56.gif) after static valve adjustment I never went back and readjusted the valves. 3 were tight. (IMG:style_emoticons/default/chair.gif) this one error caused the engine to run hotter, less power (obviously), missing, fouling plugs, some back firing ( (IMG:style_emoticons/default/slap.gif) ), and rough idling. (IMG:style_emoticons/default/dry.gif) i hope someone can benefit from my experience. (IMG:style_emoticons/default/smile.gif) best regards... |
messix |
elementary my dear Watson, elementary! (IMG:style_emoticons/default/cool_shades.gif)
Joe Ricard |
Ya'll adjust valves?
I ain't adjusted valves in 30,000 miles and only changed oil once in that time. Who am I? |
SLITS |
McMark |
Ya'll adjust valves? I ain't adjusted valves in 30,000 miles and only changed oil once in that time. Who am I? (IMG:style_emoticons/default/rolleyes.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 08:22 PM |
