911 oil pressure gauge question ... |
SirAndy |
Jun 25 2007, 04:53 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
is there an older style (pre '90s, before they went all plastic) 911 combo oil-temp/oil-pressure gauge that will work with the later style 993 5 bar sending unit?
i currently have a '74 911 S gauge and it reads exactly double. the 993 motor uses the newer style sending units with the large threads, so using an older sending unit is out of the question. is there such a thing as an earlier style gauge that works with the 5 bar sending unit? (IMG:style_emoticons/default/idea.gif) Andy |
904svo |
Jun 25 2007, 06:27 PM
904SVO Group: Members Posts: 1,119 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
Goto www.nhspeedometer.com look under vdo they list all the senders with the
threads and range of the sending units. |
bondo |
Jun 25 2007, 06:29 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Why is an older sender out of the question? The newer sender uses larger threads, so an adapter would be easy to make. I made an adapter to go the other way, which is harder. (IMG:style_emoticons/default/smile.gif)
Check my progress thread for pics of my adapter. |
SirAndy |
Jun 25 2007, 06:38 PM
Why is an older sender out of the question? because i'm tired of waiting on the machine shop for a week only to get the wrong part and then i have to wait all over again ... (IMG:style_emoticons/default/rolleyes.gif) someone on pelican mentioned that the SC and 3.2 Carrera used 5 bar sending units as well. if that is correct, i'd rather get one of them gauges ... (IMG:style_emoticons/default/idea.gif) Andy |
Cap'n Krusty |
Jun 25 2007, 07:03 PM
Call Palo Alto Speedometer. They're close by, probably have what you need in stock, and know their stuff. The Cap'n
Dave_Darling |
Jun 25 2007, 09:07 PM
914 Idiot Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
The SC does have a 5 bar gauge. Don't know the range of the sender, but the gauge is 5 bar.
...Just drove one last week, so the memory is pretty fresh... (IMG:style_emoticons/default/wink.gif) --DD |
Dr Evil |
Jun 25 2007, 09:18 PM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Maybe this will help you?
Attached image(s) |
SirAndy |
Jun 25 2007, 10:42 PM
Maybe this will help you? not really, as the '95 993 sending unit is not on there ... (IMG:style_emoticons/default/smile.gif) Andy |
McMark |
Jun 25 2007, 10:54 PM
Can you just call EASY and ask for a 5 bar or 80 psi gauge unit? There ain't nuthin' fancy about them gauges. '95 or '75, they'll work just fine.
Dr Evil |
Jun 25 2007, 11:04 PM
Duh, my bad. You have one of those rich 3.6 engines (IMG:style_emoticons/default/rolleyes.gif)
SirAndy |
Jun 26 2007, 12:07 AM
Can you just call EASY and ask for a 5 bar or 80 psi gauge unit? There ain't nuthin' fancy about them gauges. '95 or '75, they'll work just fine. already did. they couldn't come with anything that worked ... (IMG:style_emoticons/default/sad.gif) Andy |
Grngoat |
Jun 26 2007, 01:00 AM
Lurker Member Group: Members Posts: 158 Joined: 17-October 04 From: Fort Worth, TX Member No.: 2,967 Region Association: Southwest Region |
I bought a SC temp guage and sent it to North Hollywood Speedometer to put numbers on it and when it came back, they sent a new sending unit as well. It screwed right in in place of the old 993 unit. I haven't started the car yet, but it fits. Either NHS or Palo Alto will have the correct sending units.
PRS914-6 |
Jun 26 2007, 07:57 AM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
Andy, when I had North Hollywood rebuild mine, they provided me with an adapter to fit the larger hole of the 993 while using the early sender with 77 gauges.. Call them and ask for Kevin
Lo-Fi Version | Time is now: 26th June 2024 - 05:54 AM |
