67rafa |
Newbie ![]() Group: Members Posts: 17 Joined: 4-August 07 From: SoCal Member No.: 7,972 ![]() |
I am interested in a 71 914-4, and to be able to drive it it needs this part for the clutch cable that makes it sweep around to hook up to the tranny. (IMG:style_emoticons/default/sad.gif)
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
What part is it that you need? The pulley or the bracket that holds the pulley? Both should be readily available. Put a WTB: post on the parts page.
BTW, (IMG:style_emoticons/default/welcome.png) Spoke |
67rafa |
What part is it that you need? The pulley or the bracket that holds the pulley? Both should be readily available. Put a WTB: post on the parts page. BTW, (IMG:style_emoticons/default/welcome.png) Spoke I need the whole thing even the bolt. What do you call it? so I could put a WTB. How much do you think? |
john rogers |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,525 Joined: 4-March 03 From: Chula Vista CA Member No.: 391 ![]() |
The pulley's are available from Porsche but the bracket will have to come from a donner transmission.
Spoke |
The bracket, pulley, and bolts shouldn't be that much from a donor tranny. I have one here in PA although one of your SoCal buddies should have one that you could pick up. Shouldn't be too expensive.
Spoke |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Ok noobie ..... check your PM.
67rafa |
Lo-Fi Version | Time is now: 25th June 2024 - 06:48 PM |
