beech4rd |
Member ![]() ![]() Group: Members Posts: 344 Joined: 10-January 07 From: Highwoods, Saugerties, NY Member No.: 7,445 Region Association: North East States ![]() ![]() |
I'm trying to correctly route the vacuum hoses on my GA prefix 2.0l. All the diagrams I can find show a line from the distributor vacuum advance to the throttle valve housing. My housing has a bump where the nipple ( are words like that permitted on this forum?) should be, but it's not drilled out and there is no nipple. There is a nipple for the line on the vacuum advace housing. Jeff Bowlsby has a very usefull diagram of the routing but doesn't show where this line attaches. I do have the line from the back of the vacuum advance attached to the throttle body- it's the line from the front (top) I'm having the problem with.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
There should be a 4-6" piece of hose attached to the advance fitting on the distributor. It goes nowhere, and appears simply to be there to keep debris out of the can. Also to mess with your mind. The Cap'n
beech4rd |
Thank you, and that I have- Both the 6" hose to nowhere and the messed up mind.
Chris |
joeav8tor |
Member ![]() ![]() Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 ![]() |
Thank you, and that I have- Both the 6" hose to nowhere and the messed up mind. Chris do a search of vacuum hose replacement...dr 914 posted a diagram that was helpful when I replaced my vacuum hoses. (IMG:style_emoticons/default/type.gif) JOE |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
There should be a 4-6" piece of hose attached to the advance fitting on the distributor. It goes nowhere, and appears simply to be there to keep debris out of the can. Also to mess with your mind. The Cap'n (IMG:style_emoticons/default/agree.gif) Mine was the same except I actually had a fitting on the TB but it was plugged. |
Air_Cooled_Nut |
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None ![]() |
http://www.icbm.org/erkson/personal/Porsch...nuals/index.htm
Middle of the page. BTW, when the login box pops up, READ IT! It tells you how to log in (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 06:21 PM |
