Bosche Blue - did I get the right coil?, concered about resistance |
swl |
Aug 31 2007, 04:35 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Had the local bug shop order a replacement coil for me. The original OEM coil still is working but I thought I'd replace it to see if that would make starting easier. Based on on conversations here I got a bosch blue. Stock 1.7 engine and (for now) no real performance driving.
The coil doesn't have any number stamped on in it but the box says: 9 224 771 008s The only english words on the coil and box are "without resistance" I know that pertronix wants a coil with resistance around 3 ohms. I measured it (across the low voltage terminals) at just under 2 ohms (maybe 1.8). I then measured the OEM coil and got just over 2 Ohms. So assuming that my meter isn't way out of calibration, it looks like neither coil is suitable for pertronix. Is this indeed the right coil? Do you guys that use pertronix put an external resistor on either the bosch blue or OEM coil? |
Cap'n Krusty |
Aug 31 2007, 05:07 PM
The one you want is a "BC 12". The Cap'n
swl |
Aug 31 2007, 06:52 PM
Thank's Cap'n. I'll go have a chin way with my parts guy.
computers4kids |
Aug 31 2007, 07:01 PM
Love these little cars! Group: Members Posts: 2,443 Joined: 11-June 05 From: Port Townsend, WA Member No.: 4,253 Region Association: None |
swl |
Aug 31 2007, 07:25 PM
quite a discussion over on the samba. seems like the coil I got is generally considered to be a POS. Made in Mexico - good ones come from Brazil - second choice spain. There is a huge array of coils that go under the name of 'bosch blue'
http://www.thesamba.com/vw/forum/viewtopic.php?t=81958 also a nice synopsis of types here http://www.ratwell.com/technical/BlueCoil.html |
Lo-Fi Version | Time is now: 31st October 2024 - 09:31 PM |
