toon1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,849 Joined: 29-October 05 From: tracy,ca Member No.: 5,022 ![]() |
I have bounced back and forth from building the engine to getting stuff painted.
I am building a MASSIVE 1.7 (IMG:style_emoticons/default/biggrin.gif) and restoring the engine bay and most of the other areas of the back end. This car has very little rust so patching is minimal. I'm hesitant to start a resto thead, there have been so many, but here are some pics. Attached image(s) ![]() ![]() |
toon1 |
fan shroud, shock , heater shrouds, intake runners, trunk hinges. Engine bay
toon1 |
2more I left the primer in the middle of the fire wall for a few coats of Quiet car and Dynamat
rktmn247 |
Irish Green with GT envy! ![]() ![]() Group: Members Posts: 347 Joined: 18-August 05 From: Mililani, HI Member No.: 4,612 Region Association: None ![]() ![]() |
brer |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,555 Joined: 10-March 05 From: san diego Member No.: 3,736 Region Association: None ![]() |
(IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/wub.gif) (IMG:style_emoticons/default/bye1.gif) (IMG:style_emoticons/default/smoke.gif) (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/cheer.gif) (IMG:style_emoticons/default/beerchug.gif) |
toon1 |
thanks guy's, it's fun to see the transformation (IMG:style_emoticons/default/biggrin.gif)
neo914-6 |
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 ![]() |
Cevan |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,079 Joined: 11-December 06 From: Western Massachusetts Member No.: 7,351 ![]() |
More pictures!!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/aktion035.gif)
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Purdy
Isn't painting your struts going to obscure them. I love some of the pics I see here where the front suspension, highlighted from behind with a light color, strut is one color and the sway is another (usually plated), caliper, rotor. But thats just me. Party on Wayne. (IMG:style_emoticons/default/smile.gif) |
woobn8r |
Senior Member ![]() ![]() ![]() Group: Members Posts: 607 Joined: 7-January 07 From: Newmarket, Ontario, Canada Member No.: 7,435 Region Association: None ![]() |
That blue is lookin' pretty cool!...any plans for orange stripes?
Keep up the great work. Those of us that aren't as far along in our projects like to see someone "gettin' it done" so we work harder!!! More pics please. |
toon1 |
That blue is lookin' pretty cool!...any plans for orange stripes? Keep up the great work. Those of us that aren't as far along in our projects like to see someone "gettin' it done" so we work harder!!! More pics please. I was not a big fan of Oly blue but it's growing on me. It's hard to tell how the color is going to look when you are looking at 15 yr old paint. I have the inner trunk area primered and a coat of bedliner on the bottom I will take some pics. Thank's for the kind words guy's, Keith |
brer |
Aren't those little wire hold down tabs a pain?
I cut myself like 50 time trying to sand in there. |
toon1 |
yea they are, I got cut a couple times. I was using a sponge type block sander, it helped keep the hands away
EdwardBlume |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California ![]() ![]() |
Nice job! I have the same color car that needs the same work right up the street from you in Pleasanton.
How did you suspend the car? what did you use to shoot the paint? is this a garage or shop job? |
toon1 |
Nice job! I have the same color car that needs the same work right up the street from you in Pleasanton. How did you suspend the car? what did you use to shoot the paint? is this a garage or shop job? The car is up on a motorcycle jack. I used a couple of 4x4's to get it up a little higher. I am using Omni laquer paint. The paint guns where bought at Habor freight. I think I spent a total of $30 on the guns, Cheap! They work good! I was all done in the garage, I just put up some pastic. When I get to painting the outside I willrent a spray booth. |
krazykonrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,129 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 ![]() |
Looking good! Are you going to stick with olympia blue or are you gonna go Gulf?
(IMG:style_emoticons/default/beerchug.gif) Konrad |
toon1 |
made some more progress on the engine bay. The engine build has come to a screeching halt.
Here are some pics made an adapter plate for the 36-1 wheel, and modified the fan housing for the VR sensor. I will take more pics of how the adapter plate and the trigger wheel where modified for Brer's MS file. The second pic is the VR sensor plug and wire with the mods made to the tin and housing to accept it. Attached image(s) ![]() ![]() |
toon1 |
two more
The engine bay is close to ready, just a few more things to do. New( to me) e-brake cables where installed and all the old wire harness covering was removed. There is the corrogated stuff over the wires now. I added a second blower motor, I don't like having to towel the windows when they fog up. The blower motor where completely dissassembled and cleaned. It's unbelievavle how much oil was in those things. The gray stuff on the firewall is Quit car, about 4 coats. It's neat stuff, water based and east to work with. There is quite a big difference is the sound of the metal when you knock on it, it feels more solid. Attached image(s) ![]() ![]() |
toon1 |
more
I installed the Camp 914 trunk shocks today. these are slick and easy to install, took about 1.5 hrs. and a pic of the motor, notice the cheezy cool chrome P coated engine tin. Attached image(s) ![]() ![]() |
Hammy |
mr. Wonderful ![]() ![]() ![]() Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California ![]() |
Bitchin tin Keith (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 24th June 2024 - 11:28 PM |
