> Best Spark Plugs for Carburated 914?
adidas
post Oct 25 2007, 12:57 PM
A 914 that has been converted to a new single carb is carbon fouling a practically new set of Bosch Platimum spark plugs in just a few weeks. A low pressure facet style fuel pump is installed. The fuel/mixture screw is leaned out with no luck. What have you found is the best brand and heat range spark plugs for a carburated 914. Thanks
Replies(1 - 5)
VaccaRabite
post Oct 25 2007, 01:21 PM
En Garde!
Quick, get rid of the single carb before the sharks start to swarm. :-)
Single carbs don't work well with 914s, the gas has too far to go to get from the carb to the engine. Find some dual dellortos or dual webers. The carb may well be causing your plugs to foul, as the gas will kind of pool in the manifold, instead of going in properly atomized.
At least, that is my understanding of the issue.
Zach
Allan
post Oct 25 2007, 01:29 PM
Teenerless Weenie
Do you have a pressure gauge to see how much fuel pressure the pump is actually putting out. That carb probably only likes 3 - 4 lbs. I second the swap to dual carbs, but if you're stuck with what you have then NGK B6S plugs should work.
Check the pressure from the pump, if it's too much, get a regulator.
Winfield
post Oct 25 2007, 01:46 PM
QUOTE(adidas @ Oct 25 2007, 02:57 PM) *
I have dual 44m webers on my 2.0 and have been using Bosch wr7dc for track events for years w/o problems. For what that is worth (IMG:style_emoticons/default/idea.gif)
IronHillRestorations
post Oct 25 2007, 08:18 PM
I. I. R. C.
You DO NOT want those fine wire platinum plugs on a carburated engine! Plain 'ol Bosch supers will do much better. The fine wire platinums foul very easily, they are for modern injected engines.
Aaron Cox
post Oct 25 2007, 08:45 PM
Professional Lawn Dart
NGKs
- Lo-Fi Version Time is now: 4th January 2025 - 11:47 PM
