My intake will not seal., hummm. |
Eric Taylor |
Jan 2 2004, 06:24 PM
Senior Member Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 |
Well after I took the intake and sheet metal off to replace the CHT I have developed a vaccum leak which makes the car idles at about 2000.I've taken off the intake runner a couple of times and tired really scrapped off the old seal which was glued in there. I replaced the seal as well, but so far nothing has made a difference. The only thing I can think of is that the tin is getting in the way some how to prevent a good seal. I've looked at the seal while the car is running and a small amount of liquid is coming out in a small area. Any idea's on how to get a good seal? I have another seal to try as well if needed.
Thanks, Eric |
redshift |
Jan 2 2004, 06:31 PM
Well.. since we can't 'see' the leak.
(IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) M |
rhodyguy |
Jan 2 2004, 06:44 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,198 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
did you cut new isolator gaskets. try new isolators. the gaskets are all ready on both sides. make sure you get the correct ones. 2.0 or 1.7, 1.8.
kevin |
Eric Taylor |
Jan 2 2004, 06:48 PM
Kevin, I'm not quite sure what you are talking about, is that the gasket between the head and the runner? If so bought new 1.7 gasket's. I'll try and get a pic of the leak.
Eric |
Eric Taylor |
Jan 2 2004, 07:11 PM
Sorry for the crappy pic, but the leak is right about there. There may be others, but that's all I can see. It's cylinder #3
Eric Attached thumbnail(s) |
rhodyguy |
Jan 2 2004, 07:56 PM
the isolator is a large rectangular(the ones i got were dark brown) plastic/bakelite? it's piece that spaces the intake from the head. it comes with thin gaskets attached to both sides. some have 4 stud holes some have 3.
kevin |
Lo-Fi Version | Time is now: 4th January 2025 - 07:14 PM |
