to empty my tank |
to empty my tank |
dflesburg |
Jan 4 2008, 09:05 AM
Senior Member Group: Members Posts: 1,720 Joined: 6-April 04 From: Warm and Cheerful Centerville Ohio Member No.: 1,896 Region Association: None |
What do you think?
The hand pump sucks too slow. What if I take a spare fuel pump, some spare hose and a couple electical leads and this to siphon off my tank for removal... Is this a stupid idea? Will I end up on the news? |
blitZ |
Jan 4 2008, 09:13 AM
Beer please... Group: Members Posts: 2,223 Joined: 31-August 05 From: Lawrenceville, GA Member No.: 4,719 Region Association: South East States |
I use a cheap siphon from my local parts store. It's slow, but works fine.
VaccaRabite |
Jan 4 2008, 09:32 AM
En Garde! Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I used a siphon to a 5 gallon gas can (and then put the gas into my Suby). It was not the fastest way to do it, but it was much more controlled, and I think it cost me all of about $5.
And I was later able to use the siphon to remove all the water from my washing machine after it broke down when full - 3 times. :mad: No matter what you do, you are going to have as much as a gallon or so at the bottom of the tank when you finally cut the gas lines to remove the tank. Have a container on hand. Zach |
SGB |
Jan 4 2008, 09:39 AM
just visiting Group: Members Posts: 4,086 Joined: 8-March 03 From: Huntsville, AL Member No.: 404 Region Association: South East States |
It might not be as easy for an FI car, but I disconnected the fuel line at the engine, got my son to hold it in a gas jug, and turned on the ignition to run the fuel pump until the tank was empty.
Allan |
Jan 4 2008, 09:51 AM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I use a cheap siphon from my local parts store. It's slow, but works fine. (IMG:style_emoticons/default/agree.gif) 8 bucks from Harbor Freight. Took about 30 minutes to drain 8 or 9 gallons... |
type11969 |
Jan 4 2008, 11:17 AM
Senior Member Group: Members Posts: 1,231 Joined: 2-December 03 From: Collingswood, NJ Member No.: 1,410 Region Association: North East States |
I've used a facet pump to pump gas back into my bus from a 5 gallon gas can (side of the bus too close to the wall to pour the gas in from the can), takes no time at all. Secure the gas lines well, put a filter before the pump (if you care about the pump), leave nothing exposed on the wiring leads and you will be fine. May want to secure the pump to a piece of wood since it does like to dance around if just sitting on a concrete floor.
-Chris |
rjames |
Jan 4 2008, 12:11 PM
I'm made of metal Group: Members Posts: 3,996 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
QUOTE It might not be as easy for an FI car, but I disconnected the fuel line at the engine, got my son to hold it in a gas jug, and turned on the ignition to run the fuel pump until the tank was empty. (IMG:style_emoticons/default/agree.gif) It's the same for FI cars. If your tank is in the car, just connect the exit end of your fuel pump to some plastic hose from home depot and run out into the tank of another vehicle and turn the key. Unless your gas is bad you might as well just save yourself the hassle of emptying it into a container just to empty it out again into another car. Detailed instructions are on Pellican, but that's pretty much it in a nutshell. Just make sure you turn the ignition off when there's no more gas or you'll burn out your pump. |
SirAndy |
Jan 4 2008, 12:39 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
What do you think? i always let the stock pump do the work ... (IMG:style_emoticons/default/shades.gif) Andy |
bperry |
Jan 4 2008, 12:53 PM
Lurker Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
And if you have FI, you can use the relay board jumper trick to force the
fuel pump to run when the engine is not. See the Fuel Pump for Carbs Tech Article if you aren't familiar with this jumper. Just be careful about your Electronic ignition or coil while running the pump with the Ignition key on. Some can fry if the engine happend to stop with the points engaged or the electronic module enable by the magnet sensor. It would be best to disconnect the ignition system. I'd disconnect the coil at a minimum. But depending on how much gas you have by the time you read all these posts and rig up something, the gas could have drained out from the fuel lines in the lower engine compartment by simple gravity. --- bill |
SirAndy |
Jan 4 2008, 12:58 PM
And if you have FI, you can use the relay board jumper trick to force the fuel pump to run when the engine is not. See the Fuel Pump for Carbs Tech Article if you aren't familiar with this jumper. Just be careful about your Electronic ignition or coil while running the pump with the Ignition key on. Some can fry if the engine happend to stop with the points engaged or the electronic module enable by the magnet sensor. It would be best to disconnect the ignition system. I'd disconnect the coil at a minimum. (IMG:style_emoticons/default/agree.gif) this works great on a FI car ... |
balljoint |
Jan 4 2008, 01:01 PM
914 Wizard Group: Members Posts: 10,000 Joined: 6-April 04 Member No.: 1,897 Region Association: None |
If you leave it parked near my place someone will just empty the tank for you over night. (IMG:style_emoticons/default/sad.gif)
Easiest is gravity siphon, then your hand pump to finish the job. |
John |
Jan 4 2008, 06:51 PM
What do you think? The hand pump sucks too slow. What if I take a spare fuel pump, some spare hose and a couple electical leads and this to siphon off my tank for removal... Is this a stupid idea? Will I end up on the news? You could do that. I made a fuel pump siphon that we still take with us to the track. We used to run out of fuel and "stole" our gas on occasion from the tow vehicle. Dad got tired of getting a mouthful of gas so I built the fuel pump version. I even put a plug on it that utilizes the trailer plug for power and ground. Which car? If it is yours or Erik's, you could hotwire the fuel pump and pump into a can. On the 3.2, you can disconnect the fuel filter and attach a hose. On the 4-cyl, you can pull the hose for the cold start injector and add hose there. Or you could do like me and pull it out full of gas and proceed to spill gas all over everything. Gas seems to feel good in open wounds and in eyes. Good luck. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:19 AM |
