WizPorsche914 |
Member ![]() ![]() Group: Members Posts: 128 Joined: 17-December 07 From: Douglassville PA Member No.: 8,479 Region Association: MidAtlantic Region ![]() |
Hey fellas I just picked up a 72 914 locally from the original owners son. Ive wanted a 914 for years and I finally got one. I have a few questions.
I want to add a center gauge console, Is it already prewired for one ? I bought some nice Fuchs replicas. What size/brand tire do you reccommend ? Can I use the lug bolts from the steel wheels ? Weld in or Rivet in a new battery tray ? Thanks |
WizPorsche914 |
One more thing the owner said the garage noticed a small crack in the top of the engine case. Is this a Major or Minor issue ?
BiG bOgGs |
The Bogus One ![]() ![]() Group: Members Posts: 452 Joined: 25-September 04 From: Ft. Myers, FL 33967 Member No.: 2,829 Region Association: South East States ![]() |
For the rest of it, knowledgeable people will reply. (IMG:style_emoticons/default/biggrin.gif) Jim |
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
(IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) Now that you have been properly greeted. 1) not sure if it's prewired. I know 73 on is. 2) 4 lug fuchs? I ran 195/60-15s. 3) Real fuch require longer lug bolts. Not sure on the repros. 4) Weld. Battery tray rust is common. How bad it is may impact the long underneath the tray. Check and make sure the hell hole is solid. After that, check the long and make sure its not rusted. Good luck! |
KaptKaos |
Crack in case may be very bad news. Have it checked.
WizPorsche914 |
I already pulled out the tray which wasnt bad but wasnt great either. The area underneath is solid with no rust.
The car does run and drive. |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
Congrats and welcome!
> I want to add a center gauge console, Is it already prewired for one ? I don't know for sure about the wiring on a 72. If I recall correctly, the center console with gauges was a 73+ option. > I bought some nice Fuchs replicas. What size/brand tire do you > reccommend ? I hate to burst your bubble, but I'm not sure there is a such thing as a nice Fuchs replica. They're heavy and prone to cracking. That said, tire-size is dependent on the backspacing of the wheel and how much bier Hans had at lunch before he fit your fenders. Generally, a 205 will fit under 914 fenders. I have 195s on real Fuchs on my 73, and I have plenty of room left. > Can I use the lug bolts from the steel wheels ? Not advised. Alloy lug bolts are longer than the steel lug bolts for a reason. Use a bit of anti-sieze and torque them to tighten. If you gorilla them tight, you risk cracking a wheel. > Weld in or Rivet in a new battery tray ? I've seen both done. Riveting always seems a bit mickey-mouse to me, and might cause you to fail tech-inspection, should you ever choose to autocross the car. Welcome to the madness! (IMG:style_emoticons/default/biggrin.gif) -Rusty |
WizPorsche914 |
Its current inspection sticker is 10/01 I mechanic said to pass it needs a master cylinder and calipers. Finding calipers for this car is almost impossible so how hard is it to rebuild them ?
Rusty |
Did he say why you needed master cylinder and calipers? Is something stuck or leaking?
If it's been sitting around a long time, I'd recommend that you change out the rubber lines and then bleed the system. Both of those tasks are within the capabilities of a novice, can be done with simple handtools, and are relatively inexpensive. A set of SpeedBleeder brake bleeding screws will cost about 10-12 dollars and will make the job very easy. If, after that, you need calipers, they aren't too hard to rebuild... or you can send them out. Eric_Shea (here on the board) does stunning work with calipers and is very reasonably priced. Check the member's vendor's section. |
ws91420 |
Yes I have one a Lensley 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,063 Joined: 10-September 03 From: Ruther Glen,VA (halfway between sticks and civilization) Member No.: 1,137 Region Association: MidAtlantic Region ![]() |
Its current inspection sticker is 10/01 I mechanic said to pass it needs a master cylinder and calipers. Finding calipers for this car is almost impossible so how hard is it to rebuild them ? Calipers are available for order from Advance Auto parts last time I looked. Are the calipers leaking? Why is the master cylinder being recommended? |
Rusty |
QUOTE If it's been sitting around a long time, I'd recommend that you change out the rubber lines and then bleed the system. Both of those tasks are within the capabilities of a novice, can be done with simple handtools, and are relatively inexpensive. A set of SpeedBleeder brake bleeding screws will cost about 10-12 dollars and will make the job very easy. Some more explanation - as the rubber brake lines age, they swell on the inside, choking off the flow of brake fluid. Over time, eventually they will swell shut to the point that your calipers won't work. It's not uncommon on older cars that haven't been driven often. As long as you're going to need to replace the rubber lines anyways - I'd recommend you start there. (IMG:style_emoticons/default/smile.gif) |
smokey |
Senior Member ![]() ![]() ![]() Group: Members Posts: 533 Joined: 15-June 07 From: Freedom Ca Member No.: 7,816 Region Association: None ![]() |
Hey fellas I just picked up a 72 914 locally from the original owners son. Ive wanted a 914 for years and I finally got one. I have a few questions. I want to add a center gauge console, Is it already prewired for one ? I bought some nice Fuchs replicas. What size/brand tire do you reccommend ? Can I use the lug bolts from the steel wheels ? Weld in or Rivet in a new battery tray ? Thanks Hey there , and welcome . Yes It is pre wired . all 914 s have the same wiring harness . Pull up the carpet in the center area . were the cen consil will sitt .> U wiil see a male type plug that is for the center consill . Lets see some pix (IMG:style_emoticons/default/smoke.gif) |
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Hi, I had to wire my 72 for the console, it did not have the wires in it like my 74.
Do the brakes not work? Why the M/C and calipers? |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
For the center console, chances are your 72 isn't wired for a center console. That being said, the most difficult part of wiring for a console is the oil temp guage hookup. If your car doesn't have a sender unit in the taco plate (small round plate under the engine on the drivers side), then you have to obtain one and run one wire to the console.
I wired my 71 for a console and was amazed to find a spare wire under the carpet which was for the oil temp sender. The wire ran from the console area through the firewall to the relay board in the engine compartment. The wire ran across the relay board to the engine connector but the engine harness didn't have that position filled. So I got an extra wire harness and added a connector in the proper position and ran a wire from the connector to the oil sender. The other guages on the console (clock and voltmeter) are easy as just grabbing a switched and non-switched +12V lead along with a dash light lead for illumination bulbs. These leads are readily available under the dash around the fuse panel. Spoke PS: Welcome to the madness. |
smokey |
For the center console, chances are your 72 isn't wired for a center console. That being said, the most difficult part of wiring for a console is the oil temp guage hookup. If your car doesn't have a sender unit in the taco plate (small round plate under the engine on the drivers side), then you have to obtain one and run one wire to the console. I wired my 71 for a console and was amazed to find a spare wire under the carpet which was for the oil temp sender. The wire ran from the console area through the firewall to the relay board in the engine compartment. The wire ran across the relay board to the engine connector but the engine harness didn't have that position filled. So I got an extra wire harness and added a connector in the proper position and ran a wire from the connector to the oil sender. The other guages on the console (clock and voltmeter) are easy as just grabbing a switched and non-switched +12V lead along with a dash light lead for illumination bulbs. These leads are readily available under the dash around the fuse panel. Spoke PS: Welcome to the madness. I used to werk For Rich Bontempi . High Performance House Redwood city ca .I dismantled cars for the guy . I have cut up or dimantled over twenty 914s . FOR him . Every one had the spare wire s under the carpet area . they are for the center gadges . After stopping werking for the guy , i continued to buy and sell 14s . Another 20 to 25 cars Bought and sold . U may have one of the cars . Parts cars . Daily drivers and prodject cars . If there was no center concil . All had the center wires . Waiting for a center concil . the extra wires were always there . My 74 has No center concil . It dose have the exra wires under the carpet waiting for a center concil . (IMG:style_emoticons/default/smoke.gif) Attached image(s) ![]() ![]() |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Congrats, you're a sick person just like the rest of us now. (IMG:style_emoticons/default/biggrin.gif) If I am not mistaken, as long as the threads go deaper than the lug bolt is round, you're good. So the lug bolts are 14mm diameter which means they would have to thread in at least that much. I run stock 914-4 lug bolts on my VW beetle and it has replica 2.0 Fuchs. They thread in almost 20mm. You can't do that on stock 2.0 Fuchs as they are thicker (Better) than replicas. You should be okay. -Dan |
smokey |
OH Shitt . (IMG:style_emoticons/default/welcome.png) Sorry i did not give that up . (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/bye1.gif) Enjoy uss . we are very cool people . (IMG:style_emoticons/default/smoke.gif)
WizPorsche914 |
What exactly am I looking for underneath the carpet for a center console connection ?
The mechanic didnt say why it needs a master cyl. Id think because it sat. |
Spoke |
You're looking for a single wire with a female spade connector which heads towards the engine compartment.
Get a schematic for a car with the oil temp gauge (73-76) and find which connectors on the relay board the oil temp sender wire uses. Once you find this, with an ohmmeter check to see if the wire under the carpet is in fact the wire you're looking for. The ohmmeter will read zero ohms if the wire is the correct one. Don't have a volt/ohm meter? Buy one. You'll need it again and again with your new ride. Spoke |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Lo-Fi Version | Time is now: 26th June 2024 - 05:05 AM |
