Plastic Hole Plugs, how many and where? |
McMark |
Jan 11 2008, 12:45 PM
Porsche used various sizes of clear plastic hole plugs in the cars, I'd like to compile a list of:
a.) How many plugs? b.) What are their sizes? c.) Where are they located? I know there are two on the top of the transmission cross members. There are two on the bottom of the cross member on non-swaybar cars. I know they were used more places. |
boxstr |
Jan 11 2008, 01:11 PM
MEMBER:PACIFIC NORTHWEST REGION Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest |
Actually there are three in the holes in the rear trunk. There is a plastic plug for that really small hole between the two larger ones.
Craig C. Laughlin Oregon Region |
JeffBowlsby |
Jan 11 2008, 01:48 PM
914 Wiring Harnesses Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Both my 74 cars have rear sway bars and both large plastic plugs on both the top and bottom
McMark |
Jan 11 2008, 01:59 PM
Thanks guys! (IMG:style_emoticons/default/thumb3d.gif)
I remember two more, the back side of the front suspension mount in the front trunk. |
IronHillRestorations |
Jan 11 2008, 09:05 PM
I. I. R. C. Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
The small hole in the rear trunk is for the spare tire bolt.
9146FAN |
Jan 12 2008, 10:11 AM
Member Group: Members Posts: 294 Joined: 20-July 04 From: ROSSMOOR, CA Member No.: 2,378 |
My '70 has three plastic plugs on each side where the bolts that hold the rear trailing arms bolt to the suspension consul. My guess is they're 8-10mm. I don't think they were used on later cars.
There's also 3 small plastic plugs on the underside of the roll-bar. They cover the ski rack mounting holes. |
watsonrx13 |
Jan 12 2008, 04:36 PM
Advanced Member Group: Members Posts: 2,735 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
There are (3) plastic plugs on each side of the car that cover the rear suspension bolts that hold the shim plate for the rear axles...
-- Rob For the interior, there are: (5) on the bottom of the roll bar pad (7) on the front of the roll bar pad (1) on either end of the knee pad - (2) total (2) on the driver's arm rest -- Rob |
Lo-Fi Version | Time is now: 26th June 2024 - 01:22 PM |
