BigD9146gt |
OCD member ![]() ![]() Group: Members Posts: 376 Joined: 24-January 05 From: Sydney, Australia Member No.: 3,502 Region Association: Australia and New Zealand ![]() |
Hello all,
For those of you who don't know me, I make the DWDesignWerks aluminum 914-6 oil tanks. I'm in search of an original 914-6 "oil return" hardline to copy, I'll pay for shipping both ways and send it back to you the next day... as well as send you a reproduction (mandrel bent, metric spec fittings) once they are done. I usually work about 14hrs a day, and I rarely get a chance to check these postings... so if you could please respond via email it would be much appreciated. Don@DWDesignWerks.com. Cheers, Don Welch DWDeisgnWerks |
rudedude |
Senior Member ![]() ![]() ![]() Group: Members Posts: 511 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest ![]() ![]() |
Don,
I tried your email and was rejected. I think I have one on the shelf if you need. Let me know. Jule |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
sww914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,439 Joined: 4-June 06 Member No.: 6,146 Region Association: None ![]() |
I'll call him and tell him to check this thread.
BigD9146gt |
I'll call him and tell him to check this thread. Thanks Steve, just got it. Jeff, I received your email but not Jules... so i'm not sure whats going on. Jules, you responded first, so if its ready to ship, I would rather keep Jeff from going through the hassle of removing his. Again, thank you both for the timely response. |
Jeffs9146 |
No problem Don! I am pulling everything out anyway for a complete restoration so let me know if you still need it. I can pull it out tonight and since I am in California UPS Ground would have it to you by Wednesday!
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Don, I bought one of your tanks (great item!) and am still collecting parts to start my conversion this spring. I WILL BUY ONE OF YOUR OIL LINE KITS...put me first in line if it will be available this spring!
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Be aware (unless I did something wrong on my conversion) that the hardline will not fit if you use the RJ or Maddog bulkhead mount.
sww914 |
I think Don has an RJ mount on his car, he might have a trick up his sleeve?
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Be aware (unless I did something wrong on my conversion) that the hardline will not fit if you use the RJ or Maddog bulkhead mount. That is completely true. I put a factory 914/6 hardline on my car, and it would not clear the Rich Johnson mount. I called Rich, and he looked at it. No Bueno. To use a factory hard line with an RJ mount would require hacking up the mount to the point of causing structural problems. There is a Porsche flex line from (I think) a 930 that replaces the factory hard line perfectly. |
dfwteenerpr |
Newbie ![]() Group: Members Posts: 22 Joined: 22-October 07 From: lewisville, tx Member No.: 8,252 ![]() |
Be aware (unless I did something wrong on my conversion) that the hardline will not fit if you use the RJ or Maddog bulkhead mount. There is a Porsche flex line from (I think) a 930 that replaces the factory hard line perfectly. I need one of those... any body have one? |
ClayPerrine |
Be aware (unless I did something wrong on my conversion) that the hardline will not fit if you use the RJ or Maddog bulkhead mount. There is a Porsche flex line from (I think) a 930 that replaces the factory hard line perfectly. I need one of those... any body have one? Call Zims. They should have them in stock. You can go pick it up today. |
Jeffs9146 |
Don,
It will be at your place on Thursday! Let me know if you want the tracking #. Attached image(s) ![]() |
BigD9146gt |
Be aware (unless I did something wrong on my conversion) that the hardline will not fit if you use the RJ or Maddog bulkhead mount. There is a Porsche flex line from (I think) a 930 that replaces the factory hard line perfectly. I need one of those... any body have one? GPR makes the flex line substitute for the 914-6. (800)321-5432, talk to Derek. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
QUOTE There is a Porsche flex line from (I think) a 930 that replaces the factory hard line perfectly. 70-71 911 |
Jeffs9146 |
OK, I got it back today Don! Thanks for the quick turn around! I can't wait to see what you end up with! (IMG:style_emoticons/default/popcorn[1].gif)
jim912928 |
Don...will this work with a six conversion with the RJ mount?
Jeffs9146 |
QUOTE That is completely true. I put a factory 914/6 hardline on my car, and it would not clear the Rich Johnson mount. I called Rich, and he looked at it. No Bueno. To use a factory hard line with an RJ mount would require hacking up the mount to the point of causing structural problems. As stated above, the line will not work with the RJ mount! |
Lo-Fi Version | Time is now: 26th June 2024 - 02:43 PM |
