Oil Leak....Rear main seal |
415PB |
Jan 10 2004, 02:31 PM
Member Group: Benefactors Posts: 498 Joined: 7-August 03 From: So Cal Member No.: 996 |
I finished my rebuild about a month ago. I've driven my teener for only about 20 miles since. I have a small puddle of oil on the garage floor, which I believe is coming from the small window in between the engine and tranny. I drove it today for a couple of miles, parked it in the garage and it immediately began to drip oil from the above location. I checked my oil and it is about an eighth inch to a quarter inch above the full mark. I guess I over filled the oil. I replaced the rear main seal during my rebuild and can't imagine that this is the problem. It is definately oil and not gear oil. How hard would it be to remove just the tranny and not the engine. I don't think I can go through removing the engine again, but I will if I have too. Any suggestions are greatly appreciated.
Thanks, Rod |
redshift |
Jan 10 2004, 02:36 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
It can be done, it is done, and you can find out how when someone comes along how already has done..
I just wanted to tell you it can be done, hope you feel better. M -they are going to say it takes less time to do the whole drop..- |
Bleyseng |
Jan 10 2004, 02:51 PM
Aircooled Baby! Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Is it engine oil or tranny fluid? Tranny fluid is thicker and smells alittle like eggs. Sometimes, hell most times, if you pull the motor you can disturb the pilot shaft seal. If its old and hard then voila! Oil leak!
Geoff |
McMark |
Jan 10 2004, 03:44 PM
Just think of removing the engine as an investment. It only takes me about an hour and a half when I'm not busting ass. The more you do it, the easier it is.
thesey914 |
Jan 10 2004, 03:59 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
It's pretty easy to remove just the tranny and I've done to change the rear crank seal. Remove starter, un-do driveshafts, chock the rear of the engine so it doesn't hang on its mounts and whip out the gearbox -two gearbox mounts and the three remaining bolts on the engine (starter is one of the four). Don't forget the earth strap! (I always do)
You can lower the 'box on a car jack its not that heavy. Might be wise to get a clutch alignment tool.... I didn't have one and used a deep socket that fit. May as well get a new thrust bearing for the flywheel too while your in there. Make sure to index your flywheel so it goes on the same position it came off for balance purposes. . -j |
type47 |
Jan 10 2004, 04:19 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
while you're in there, check out the oil galley plugs.
415PB |
Jan 12 2004, 01:43 PM
Okay, so I was mistaken. The fluid on the floor is thicker than oil and smells nasty. So I am thinking this is gear oil. Can anyone tell me what on the tranny would cause this leak between the tranny and engine.
Thanks |
SirAndy |
Jan 12 2004, 02:16 PM
Resident German Group: Admin Posts: 41,806 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(415PB @ Jan 12 2004, 11:43 AM) Can anyone tell me what on the tranny would cause this leak between the tranny and engine. main shaft seal on the tranny. (or the seal on the little pivot). just replaced mine this weekend, had the same problem. gear lube dripping out of the tranny. you NEED to get this fixed ASAP cause it's also getting into the clutch and if the clutch disks get soaked, they're toast! Andy |
seanery |
Jan 12 2004, 02:32 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
speedo's drive can spew oil, too. Was the speedo working?
SirAndy |
Jan 12 2004, 02:38 PM
QUOTE(seanery @ Jan 12 2004, 12:32 PM) speedo's drive can spew oil, too. Was the speedo working? he said: "which I believe is coming from the small window in between the engine and tranny" about a foot away from the speedo. (IMG:style_emoticons/default/wink.gif) Andy |
Bleyseng |
Like I said earlier, if you take the motor out chances are that pilot shaft seal if old, will then leak. Pull out the tranny like was said and install one quick. Its pretty easy although tricky to remove the old seal if you don't have a seal puller. Make sure to clean and check the shaft for scratches and burrs so the seal won't just leak again.
Might as well install new tranny fluid while you are at in. Geoff |
SirAndy |
Jan 12 2004, 02:42 PM
QUOTE(Bleyseng @ Jan 12 2004, 12:38 PM) Its pretty easy although tricky to remove the old seal if you don't have a seal puller. it's pretty easy without puller. hit the seal on one side (i used a ratchet extension and a BFH). the seal will start to move IN while the opposite side will move OUT. once the seal is in an angle, you can pull it out with a screw-driver. takes about a minute. Andy |
415PB |
Jan 17 2004, 06:09 PM
Andy, is this the main shaft seal we are talking about? I am having a hell of a time trying to get it out. My seal puller is too big. Any suggestions?
Thanks, Rod Attached image(s) |
Matt Romanowski |
Jan 17 2004, 07:00 PM
Senior Member Group: Members Posts: 878 Joined: 4-January 04 From: Manchester, NH Member No.: 1,507 |
Try using some picks to start prying it and get it going. You'll never get a traditional seal puller in there. Also, be careful not to score the pinion shaft. Use lots of lube when installing the new one and make sure the inside (part that is against the shaft) is laying flat.
Matt |
SirAndy |
Jan 17 2004, 07:09 PM
QUOTE(415PB @ Jan 17 2004, 04:09 PM) Any suggestions? yupp, use something blunt, like a (small) wratchet extension and hammer away in one spot (very close to the shaft). the seal will move in on that side and tilt (the other side will come out), then grab it either with plyers or use a screwdriver to pry it out. be carefult not to scratch the shaft or the surface of the hole. Andy |
415PB |
Jan 17 2004, 09:39 PM
Thanks, I got the seal off but it appears the PO might have used some type of sealant. It appeared to have been glued on. The portion of the seal that goes into the tranny was very brittle and some very small pieces fell into the tranny. Should I be concerned with this or should I try and fish the pieces out? I have been trying for like two hours with no luck.
Thanks |
SirAndy |
Jan 17 2004, 09:50 PM
QUOTE(415PB @ Jan 17 2004, 07:39 PM) Thanks, I got the seal off but it appears the PO might have used some type of sealant. It appeared to have been glued on. The portion of the seal that goes into the tranny was very brittle and some very small pieces fell into the tranny. Should I be concerned with this or should I try and fish the pieces out? I have been trying for like two hours with no luck. Thanks were they rubber or part of the metal inside the seal? the rubber probably won't do any harm, not sure about larger metal pieces. if metal, try a magnet on a extension. Andy |
Brad Roberts |
Jan 17 2004, 10:51 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Make damn sure you check the pivot ball for the clutch fork. I'm to the point now that I check ALL of them when we have the tranny's out. I have been bitten too many times. I pull them out and load them up with some good sealant and screw them back in.
B |
415PB |
Jan 17 2004, 11:12 PM
I'm pretty sure they were small pieces of rubber so I probably wont do much about it then. As for the pivot ball, I did notice that it is leaking. I will take it off and seal it up. Thanks for the help.....
415PB |
Jan 24 2004, 02:32 PM
Andy, does this metal ring have to come out as well, or is it part of the tranny.
Thanks, Rod (Feeling stupid in Cali) Attached image(s) |
Lo-Fi Version | Time is now: 21st September 2024 - 07:00 PM |
