> OIL YOUR TRUNK HINDGES TODAY !, or eles
jsayre914
post Feb 27 2008, 11:18 AM
Speed Up !!!
I Opened my trunk and the drivers side hindge bolt sheered off (IMG:style_emoticons/default/mad.gif) I had to remove the deck lid drill out the side on the car, then the head of the bolt had fused itself onto the hindge bracket (IMG:style_emoticons/default/mad.gif) Finally I got it off 2 hours later. Please oil yours today, front and back.
Replies(1 - 12)
pete914
post Feb 27 2008, 11:20 AM
Man, I hear that! What a pain...
alpha434
post Feb 27 2008, 11:21 AM
My member number is no coincidence.
It's no coincidence that you haven't been voting for Mrs. K.
Let this be a lesson to the rest of you. Vote for Mrs. K, or your defunct german cars will be even more defunct.
Lol.
pin31
I've sprayed on a dry lubricant on mine (thinking less mess)..worked OK (not great).
What do the "wise ones" recommend?? White lithium grease?
rick 918-S
post Feb 27 2008, 11:30 AM
Hey nice rack! -Celette
QUOTE(alpha434 @ Feb 27 2008, 09:21 AM) *
Lol.
(IMG:style_emoticons/default/av-943.gif)
alpha434
post Feb 27 2008, 11:32 AM
QUOTE(pin31 @ Feb 27 2008, 12:21 PM) *
The wise ones recommend voting for Mrs. K. Apply liberally for the next 62 days.
jsayre914
post Feb 27 2008, 11:40 AM
Speed Up !!!
QUOTE(alpha434 @ Feb 27 2008, 12:21 PM) *
Lol.
(IMG:style_emoticons/default/bootyshake.gif) I have in fact voted, I think I have about 8 votes in, that is why it is ONLY a trunk bolt. (IMG:style_emoticons/default/biggrin.gif)
alpha434
post Feb 27 2008, 11:42 AM
That's right. IT's only a trunk bolt. Thank your stars that you were voting, or else it could have been a high speed wheel bolt failure!!!
jsayre914
post Feb 27 2008, 12:10 PM
Speed Up !!!
(IMG:style_emoticons/default/dry.gif) I just emptied a medium size can of wd-40 on my car, overkill i think. I did the front hinge rear hinge trunk springs any bolt that looked iffy, opend the doors and did the channels cranks hindges door stay handles door clickers. the pedal cluster the front trunk release the rear trunk release clutch pulley accelerator cable seat hindges and channels adjusters etc. emergency brake. Did I Forget anything?? (IMG:style_emoticons/default/blink.gif)
degreeoff
post Feb 27 2008, 12:29 PM
I like big butts and I can not lie!
QUOTE(rick 918-S @ Feb 27 2008, 09:30 AM) *
Lol.
I Voted!!! Damn that was close!!
SGB
post Feb 27 2008, 12:32 PM
just visiting
"ol WD-39.9 is more cleaner than lube. I use wheel bearing grease on all the hinges on my car.
Despite the opportunity, for the sake of political or cultural correctness I have chosen not to reference "Mrs K" in the same context as "lube". Chris already associated her with "shower", so I will show you that it isn't MY mind in the gutter.
alpha434
post Feb 27 2008, 12:59 PM
Shower?
rhodyguy
post Feb 28 2008, 08:41 AM
while you're in there...replace that wornout plastic wheel or loose the springs and install a camp914 trunk strut kit.
k
- Lo-Fi Version Time is now: 26th December 2024 - 04:19 AM
