tracks914 |
Canadian Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None ![]() ![]() |
I bought a LED universal brake light on Ebay for about $8. I bought as short a light as I could get.(24 LED's and about 7 1/2" long) I took it apart and determined that it could fit into my roll bar trim. Since I just bought a parts car I felt I had an extra roll bar trim to experiment with...so I did. The trim will be painted black so it should blend in even better.
I've yet to mount it on the car, it will be tight but I think I can make it work. Either way, for $8 it was worth the dream of a nice high mounted brake light. Attached image(s) ![]() ![]() ![]() ![]() |
dw914er |
Planning Cities ![]() ![]() ![]() ![]() Group: Members Posts: 2,364 Joined: 1-March 08 From: Yucaipa, CA Member No.: 8,763 Region Association: Southern California ![]() |
very cool
TINCAN914 |
Summer's Commin... ![]() ![]() ![]() ![]() Group: Members Posts: 2,440 Joined: 18-August 05 From: Colorado Springs, CO. Member No.: 4,611 Region Association: Rocky Mountains ![]() |
Cool let us know how it works out. How will you wire it? Just hook it up to the existing brake lights?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Cool let us know how it works out. How will you wire it? Just hook it up to the existing brake lights? you could run the wire behind the trim all the way down one side, exit at the bottom of the trim into the engine bay and from there to the rear brake lights ... (IMG:style_emoticons/default/idea.gif) Andy |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
You know...
That's a "really" good idea. I don't know how many teeners have been rear ended (settle down Slits). I have this theory that because of the low nature of our cars and the multitude of larger vehicles on the road, we have a taillight issue. This is one of the first truly "clean" installs I've seen. Keep us posted. |
lotus_65 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,608 Joined: 21-March 05 From: minneapolis, mn Member No.: 3,795 Region Association: Northstar Region ![]() |
I was hoping to do this, but the LED's I got where too long and didn't sit as flush with the trim as I'd hoped so I didn't do it.
I'm looking forward to your install! |
BarberDave |
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest ![]() |
I have mine mounted to the engine tray. I agree with Eric we need all the extra light back there we can get. Does any one have experence with LED'S in tail lights, Are they that brighter and installation ease? Dave (IMG:style_emoticons/default/slap.gif) |
gopack |
CHEESEHEAD in CA, MARK ![]() ![]() ![]() Group: Members Posts: 744 Joined: 7-August 04 From: Folsom, CA Member No.: 2,472 Region Association: Northern California ![]() |
Great idea! I wish I had thought of that!
here is my solution to the same problem. (brake light from a Honda Del Sol, also on ebay, $25) THe details are in my (lack of) progress thread in my sig line! ![]() ![]() ![]() |
Katmanken |
You haven't seen me if anybody asks... ![]() ![]() ![]() ![]() Group: Members Posts: 4,738 Joined: 14-June 03 From: USA Member No.: 819 Region Association: Upper MidWest ![]() |
Nice work...
Making a clean slot in a "U" channel can be quite pissy. I can see a lotta careful filing and fitting. Got a seal to prevent water ingress? Ken |
roadster fan |
Project Frankenstein !!!!!!!! ![]() ![]() ![]() Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California ![]() |
Nice (IMG:style_emoticons/default/smilie_pokal.gif) Keep us posted on the progress of the install, very creative.
Jim |
GeorgeRud |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest ![]() |
There was a car at the SMOG Midwest Gathering 2 years ago that did the same thing using the 3rd brake light from a Ford GT, and it looked great. He did have to notch the rollbar to fit the LEDs in, but the final effect was wonderful. There was a thread on his install on the old list, not sure if it's available anywhere anymore.
I rushed and bought the light, but still have not gotten around to modifying my car. Maybe this summer! |
tracks914 |
QUOTE you could run the wire behind the trim all the way down one side, exit at the bottom of the trim into the engine bay and from there to the rear brake lights ... (IMG:style_emoticons/default/idea.gif) Andy Andy that's my plan. I figure I might have to notch out the roll bar a bit, but the wiring will be the easy part. To seal it I plan to use good old RTV silicone. Since I don't drive in the rain or snow, the only water my 914's see is from the hose when I wash it. As for cutting the hole, I started with a drill bit, then used a jig saw /metal blade, then a dremel tool to clean it up and finally a file to smooth the edges and square the corners. It's been quite easy so far. I'll take pictures when I get it installed, probably in the next couple of months... I now have a parts car (P4) to tear down and store all the good parts before I continue with P2. |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Nice idea, I like it. I've been rear ended in my red 914 and I like the 3rd brake light in the roll trim. A brake light that high is about even with the normal brake lights on SUVs.
retrofit |
Member ![]() ![]() Group: Members Posts: 176 Joined: 17-April 04 From: Turlock,Ca Member No.: 1,943 ![]() |
(IMG:style_emoticons/default/beerchug.gif) I Like It! Clean solution to a common problem.
Allen |
rascobo |
Member ![]() ![]() Group: Members Posts: 203 Joined: 26-July 07 From: Portland,OR. Member No.: 7,948 Region Association: Pacific Northwest ![]() |
Nice! I've used several different thin fixtures mounted to the underside of roll bar over the years,(Caddy STS w/intrigrated
turn signals and aftermarket heat re-formed pickup light bars) but none as clean as your inset solution(s). Now a new project to add to the list. |
Garland |
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,331 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest ![]() ![]() |
There was a car at the SMOG Midwest Gathering 2 years ago that did the same thing using the 3rd brake light from a Ford GT, and it looked great. He did have to notch the rollbar to fit the LEDs in, but the final effect was wonderful. There was a thread on his install on the old list, not sure if it's available anywhere anymore. I rushed and bought the light, but still have not gotten around to modifying my car. Maybe this summer! Here it is (the link to my 3rd brake light posting) |
ericread |
The Viper Blue 914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California ![]() |
Does much light reflect back into the passnger area form the back window whenn the light is engaged? It looks really, really good, but I am concerned about light backwash.
TravisNeff |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,082 Joined: 20-March 03 From: Mesa, AZ Member No.: 447 Region Association: Southwest Region ![]() ![]() |
I have one on my engine lid, there is no lightwash from the light into the passenger compartment.
tracks914 |
Just an update. I installed the light on my car. I had to trim most of the bottom lip off the inside of the trim piece to get it to fit without grinding away any of the roll bar but it worked pretty good. The trim will be painted black to match the rest of the trim on the car and the ends of the light will have to be sealed but I am happy with the finished product.
Attached image(s) ![]() ![]() ![]() |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Nice ........................ I did Gwen's something like that, I think. Been a few years, and I disremember perzackly. FWIW, mounting it on the engine lid kinda defeats the concept of "center high mounted stop light", doesn't it?
The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 12:47 AM |
