vesnyder |
Senior Member ![]() ![]() ![]() Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 ![]() |
After dinking with gauge lights behind my dash my lights no longer work? Any chance that I burnt out my headlight switch? It seems like I did this before and after replacing my headlight switch it solved the problem. Any other ideas?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Sometimes the little rheostat (brightens & dims dashlights) on the back of the headlight switch gives up. Look at the switch and count the pins ... it'll tell you which one you need.
If you dinked you may have knocked a wire loose, kicked a fuse out or ???? |
r_towle |
There is a common ground for the instrument lights that runs in series...make sure its connected.
Rich |
vesnyder |
The rheostat is a goner, but still not entirely sure that is my problem. Tried to see how many pins on my current switch and could not see - need to remove the fuse box.
Lo-Fi Version | Time is now: 26th June 2024 - 03:12 AM |
