michel richard |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 ![]() |
Hi, I just ordered a crane Fireball ignition system and the instructions talk at length about coil resistances and the need for a resistor. I have several coils in my parts bin, but I'm not sure they're right. Crane says that if one is not sure, one should use a resistor. That's what I would like to do. Does anyone have an application that I can give at my Flaps for them to find a part that will work ? i.e. if I walk into the Flaps and ask for an ignition resistor for a 1972 BMW 2002, will I end up with what I need: a 1.8 ohm (approximately) automotive grade resistor that I can bolt somewhere and wire in line with the positive lead to my coil. TIA Michel Richard p.s. this is not for the 914-6 twin plug short stroke . . . I'm getting a twin plug distributor and will run twin CDI boxes on that car ! |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
Michel,
I did a little research looking for the correct match for a pertronics setup which wants a 3ohm coil. The standard bosch (black) coil has a 3 ohm internal resistor. Some of the bosch 'blue' also have the 3 ohm resistor - not all though. Pertronics was the only non-bosch I found with 3-ohms. |
michel richard |
Steve,
Thanks for your response. I too see just about 3 ohms on one of my black Bosch coils. But I cant find a part number to figure exactly what it is and the instructions call for a minimum 3.2 ohms. I'm being a little anal about this because I fried one of these systems a couple of years ago. I'll Crane tomorrow see what they say. Cheers Michel |
Joe Owensby |
JoeO ![]() ![]() ![]() Group: Members Posts: 527 Joined: 7-January 06 From: Spartanburg, SC Member No.: 5,385 Region Association: South East States ![]() |
I asked a local Advance auto parts guy about a resistor, but he couldn't find one. I just checked on their websiet on line ordering location. Did a search under resistor, and I was a able to find one under ballast resistor.
Steve Thacker |
UMMMPH Yea Baby Yea ! UMMMPH ![]() ![]() ![]() Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest ![]() |
Michel,
I too am running the Crane unit. Please let me know what Crane tells you. I have cooked more than a few coils. I have a external ballast resister I can use, but not sure if it is the right one. Here is one http://www.hot-spark.com/HS14BR.htm |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
I would think that any 3 ohm coil that's intended for use without a ballast resistor (because it's built into the coil) would work? (IMG:style_emoticons/default/confused24.gif) Measure the resistance of the coil. Talk with Crane and ask them about using a 3 ohm coil?
Gint |
Michel, (IMG:style_emoticons/default/agree.gif) ...what he said.I did a little research looking for the correct match for a pertronics setup which wants a 3ohm coil. The standard bosch (black) coil has a 3 ohm internal resistor. Some of the bosch 'blue' also have the 3 ohm resistor - not all though. Pertronics was the only non-bosch I found with 3-ohms. |
Lo-Fi Version | Time is now: 26th June 2024 - 12:12 AM |
