Oil Pooling Under Carbs? |
vesnyder |
May 17 2008, 04:52 PM
Senior Member Group: Members Posts: 680 Joined: 14-April 05 From: Cleveland, OH Member No.: 3,933 |
Still in the process of working the kinks out of my rebuilt carbed motor but just got back from a spirited run with some long right hand curves and when I returned home there was oil pooling under the drivers side carb. I assume this was from the long right turns but where could it be coming from? The car was overfilled with oil but is has gotten back to normal levels.
r_towle |
May 17 2008, 04:57 PM
Custom Member Group: Members Posts: 24,680 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
do your head vent tubes run into the carbs directly?
Rich |
vesnyder |
May 17 2008, 06:56 PM
Head vent tubes?? Good question - but I suspect there must be some vent that dumps into the engine bay. Could the motor haqve been too full of oil or can I close the vent?
r_towle |
May 17 2008, 06:59 PM
There are head vent tubes in some heads.
Look just under and behind the intake manifold to see if you have a 10mm tube coming out of the head. If actually vents the valve cover rocker arm area. You may have just had a hose come loose...and they can spray quite a bit. If you have carbs...the head breathers will go into one of two typical places. They can be connected to a breather box, or connected directly to the intake air filter. Rich |
Lo-Fi Version | Time is now: 4th January 2025 - 07:38 PM |
