> Fuse Box, Question
Mavrick272
post Jul 9 2008, 09:45 PM
are all the fuses on the fuse box the 8 amp white ones?
I got this car in "as is" condition and I am not sure if the fuses were replaced correctly...
thanks
Replies(1 - 6)
jsayre914
post Jul 9 2008, 09:59 PM
Speed Up !!!
Fuses and their values are described in the 914 owners manuals. If you are without an owners manual, the following is provided:
If you have a 1970 thru 1973 914, the values are:
Position Value Item
1 8 High beam, left
2 8 High beam, right
3 8 Low beam, left
4 8 Low beam, right
5 8 Parking light, left
6 8 Parking light, right
7 8 License plate lights
8 25 Wipers, horn, fan, lighter
9 8 Tail lights
10 8 Fog lights
11 8 Emergency flashers
12 25 Retracting headlights
1974 and later fuse descriptions and sizes are similar, except fuse positions 8, 10, and 12 are 16 amps.
The amp ratings are marked on the ceramic body of the fuses themselves. They are color coded as follows:
8 amp - white
16 amp - red
25 amp - blue
If you get disoriented as to what end is what on the fuses and positions, you can lower the fuse panel by taking out the two screws that hold it to the underside of the dash. At position 1 there are white wires on the connectors, and at position 12 there are red wires.
Jon Lowe - PCA WebSite - 5/24/2002
Eric_Ciampa
post Jul 9 2008, 10:00 PM
CHAMP914
Here is the link to the PP site with all the information you need. I have had to print it out more than a few times.
http://www.pelicanparts.com/914/technical_...rical_fuses.htm
Edit: jsayre914 beat me to it.
ericread
post Jul 9 2008, 10:13 PM
The Viper Blue 914
Here's a link to Jeff Bowlsby's rare documents website. There is a 1974 2.0L Owner's Manual third from the top.
http://members.rennlist.com/914_collectibles/RareDocs.htm
Jeff's got some amazing stuff, so when you get time check it all out.
Eric Read
Mavrick272
post Jul 9 2008, 10:18 PM
awesome
thanks guys!
Mavrick272
post Aug 3 2008, 10:15 AM
ok, so what do I do if my fuse panel cover is missing?
Does fuse #1 start on the left side or the right side?
(I'm assuming left)
ejm
post Aug 3 2008, 10:21 AM
I can see the light at the end of the tunnel
(I'm assuming left)
Correct..the drivers side...the cover isn't numbered anyway
- Lo-Fi Version Time is now: 22nd December 2024 - 06:11 AM
