G e o r g e |
Dr ![]() ![]() ![]() Group: Members Posts: 1,905 Joined: 20-September 05 From: Southern Cal Member No.: 4,832 Region Association: None ![]() ![]() |
What are you running behind the header?
I have a super trapp and it is just to loud. what are my options? |
Zundfolge |
Senior Member ![]() ![]() ![]() Group: Members Posts: 847 Joined: 12-August 07 From: Colorado Springs Member No.: 7,994 Region Association: Rocky Mountains ![]() |
You can take a bunch of diffuser disks off the Supertrapp and it'll be a little quieter.
I happen to love annoying my Harley driving neighbors with the loudness (I have 8 disks in mine). Since its just a pipe (I don't think there's a flange ... I'll have to look) pretty much any muffler will work ... or at least can be made to work. |
hydroliftin |
Member ![]() ![]() Group: Members Posts: 373 Joined: 8-November 06 From: Vallejo, CA Member No.: 7,180 Region Association: Northern California ![]() |
You can take a bunch of diffuser disks off the Supertrapp and it'll be a little quieter. I happen to love annoying my Harley driving neighbors with the loudness (I have 8 disks in mine). Since its just a pipe (I don't think there's a flange ... I'll have to look) pretty much any muffler will work ... or at least can be made to work. |
G e o r g e |
I'm running 12 disks
I'll drop them down to 6 my header has a 3" 3 bolt flange, I was hoping somebody knew of a muffler that could bolt on I guess i'll have to get 1 made up (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/welder.gif) |
Zundfolge |
Yep, just had to run out to the parking lot to throw the roof on (rain a comin') and looked under the car, there is a flange.
well if you didn't mind destroying the Supertrapp, you could cut the flange off it and weld it to any other muffler. |
r_towle |
Autozone sells hush thrush mufflers. Its an oval muffler.
Its very open, but tones down the 914 nicely. They dont sell flanges, but a decent muffler shop will sell you a flange, or they will even tig one on your muffler for you. I had an original (pre Foley) header like foley makes. I got the muffler and flange...welded it up and added a bolt on tail pipe to pass tech/noise inspection..simple. Rich |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
What are you running behind the header? I have a super trapp and it is just to loud. what are my options? I recommend a long pipe (about 36" long) from the flange that makes a turn behind the tranny to a conventional chambered muffler, and a tailpipe on the other end. |
G e o r g e |
I recommend a long pipe (about 36" long) from the flange that makes a turn behind the tranny to a conventional chambered muffler, and a tailpipe on the other end. Chris Should the 36" pipe be the same size as the collector? my other option is to install that 1st generation setup I have that you made.. how quiet is this setup? Attached image(s) ![]() |
ChrisFoley |
If you have that, what are you messing around with the KHH for?
More power, quieter, nicer sound, heat, looks cool, new, more power. Just the Stage I is as loud as the Supertrapp with no plates. Adding the second stage silencer makes it quite reasonable for the street. The KHH extension pipe should be 2 1/8" or 2 1/4". BTW, I can help you update the Tangerine heat exchanger to distribute air to both sides of the cockpit. |
G e o r g e |
That's what i thought you would say
I'll swap it out Sat. where should i mount my 02 sensor on this , after all 4 have tied together? right now I wasn't going to run heat, but by using this setup It will probably be a project for the future |
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
If you have that, what are you messing around with the KHH for? (IMG:style_emoticons/default/agree.gif) Why are you even asking about the KHH if you have that piece of art lying on your floor, and not bolted up to your motor????? -Josh2 |
ChrisFoley |
where should i mount my 02 sensor on this , after all 4 have tied together? Yes, just after the secondary collector. QUOTE right now I wasn't going to run heat, but by using this setup It will probably be a project for the future The heat exchanger is easily installed as a separate project. |
Lo-Fi Version | Time is now: 26th June 2024 - 07:48 AM |
