Accelerator Cable problem, Cable/mounting issue |
golfcas |
Aug 22 2008, 01:49 PM
Newbie Group: Members Posts: 8 Joined: 17-July 08 From: Issaquah, WA Member No.: 9,311 Region Association: Pacific Northwest |
Hello. I have a 1975 914 2.0 which the FI systen was taken out at some time and replaced with 2 weber carbs. Well, the accelerator cable broke and the standard 914 replacement will not work as it is not a fi system. Is there a way to have explained or a picture of how someone else has converted their car to dual carbs and shows what the bracket looks like, the type of cable used and any other information which would help me?
Thank you very much. |
SirAndy |
Aug 22 2008, 01:52 PM
Resident German Group: Admin Posts: 41,694 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is there a way to have explained or a picture of how someone else has converted their car to dual carbs and shows what the bracket looks like, the type of cable used and any other information which would help me? When i had my 2056, i used the stock (FI) cable with a custom bracket. (IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
golfcas |
Aug 22 2008, 02:44 PM
Is there a way to have explained or a picture of how someone else has converted their car to dual carbs and shows what the bracket looks like, the type of cable used and any other information which would help me? When i had my 2056, i used the stock (FI) cable with a custom bracket. (IMG:style_emoticons/default/bye1.gif) Andy Thank you very much. I will follow this advise and I really appreciate your help. |
SirAndy |
Aug 22 2008, 03:31 PM
Thank you very much. I will follow this advise and I really appreciate your help. Btw. it's hard to see in the pic, but the bracket is a triangle with the other leg mounted to the bolt near the base of the oil filler opening. (IMG:style_emoticons/default/shades.gif) Andy |
golfcas |
Aug 22 2008, 03:45 PM
Thank you very much. I will follow this advise and I really appreciate your help. Btw. it's hard to see in the pic, but the bracket is a triangle with the other leg mounted to the bolt near the base of the oil filler opening. (IMG:style_emoticons/default/shades.gif) Andy Did you buy the cable from Pelican? The reason I ask this is because I ordered a standard 914 cable and it should have been for a FI, I believe, since that the the original configuration. Also, it doesn't look like the one you have in your picture. Would you mind helping again with you knowledge? Thanks |
SirAndy |
Aug 22 2008, 03:51 PM
Did you buy the cable from Pelican? The reason I ask this is because I ordered a standard 914 cable and it should have been for a FI, I believe, since that the the original configuration. Also, it doesn't look like the one you have in your picture. Would you mind helping again with you knowledge? Nope, that's the stock cable that was in my car before i put the 2056 in. The car had a 1.7L with stock DJet FI ... (IMG:style_emoticons/default/driving.gif) Andy |
golfcas |
Aug 22 2008, 04:14 PM
Did you buy the cable from Pelican? The reason I ask this is because I ordered a standard 914 cable and it should have been for a FI, I believe, since that the the original configuration. Also, it doesn't look like the one you have in your picture. Would you mind helping again with you knowledge? Nope, that's the stock cable that was in my car before i put the 2056 in. The car had a 1.7L with stock DJet FI ... (IMG:style_emoticons/default/driving.gif) Andy Thanks again, Andy. I think I have enough to go now. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:21 AM |
