> rear brake adjuster not working!
monkeyboy
post Aug 26 2008, 01:14 PM
I just installed a new set of PMB rear brake calipers, and pads. When I go to adjust the venting clearance, the passenger side, outside adjuster does nothing. I got the driver side adjusted just fine.
Can anyone help?
I did search, and tried to use my air gun to get it back on track and didn't have any success. I do know that it needs to be turned counterclockwise, but if it was turned the wrong way, could it have come apart inside?
Thanks
Replies(1 - 10)
davep
post Aug 26 2008, 01:29 PM
914 Historian
Use of an air gun is almost guaranteed to cause trouble.
Yes, you can pop it apart inside, although that would be rare in this instance.
I would try to get the piston moving by stepping on the brake. You may need to put in a thin brake pad, move the piston out a little, then force it back in. This is just to get the piston moving a little. Sometimes the internal mechanism will spin inside of the piston if there is less friction there than the piston sliding in the bore. This can happen more often when the mechanism is lubed during the install process. There is no lock as such between the mechanism and the piston, and what will move is the part with the least resistance.
monkeyboy
post Aug 26 2008, 01:33 PM
Thanks, I will try that. I only used an air gun to pop it because I saw that suggested by Eric in another thread.
monkeyboy
post Aug 26 2008, 02:43 PM
Still spinning freely. Any other ideas?
Cap'n Krusty
post Aug 26 2008, 02:58 PM
Cap'n Krusty
QUOTE(davep @ Aug 26 2008, 12:29 PM) *
Well, I don't think that's true .................. Inner and outer adjusters are linked to the pistons, and you MUST apply pressure on the piston as you turn the adjuster to retract it. You don't have to use pressure to move it out. Failure to push on the piston while retracting it can (and frequently does) cause the adjuster mechanism to become disengaged. That's not good.
The Cap'n
monkeyboy
post Aug 26 2008, 03:02 PM
QUOTE(Cap'n Krusty @ Aug 26 2008, 01:58 PM) *
The Cap'n
If I turned it the wrong way when I first installed it, and it came disengaged, how would I reengage it? Do I have to take the whole caliper apart?
Eric_Shea
post Aug 26 2008, 04:24 PM
PMB Performance
If you turned it the wrong way the spring may have popped but, that's kinda rare.
The air method to release the piston can work if you go in the proper direction. You need to spin it counter clockwise fairly fast (short bursts). This will spin the adjuster faster than the mass of the internal piston can compensate for and get the piston moving.
If you can't get it, send it back. I'll be back Friday and I can have it on the way back to you Saturday.
monkeyboy
post Aug 26 2008, 04:29 PM
QUOTE(Eric_Shea @ Aug 26 2008, 03:24 PM) *
I will give it another shot and let you know. Thanks for the help.
monkeyboy
post Aug 26 2008, 07:24 PM
Couldn't get it to work, but I did get it in the mail. It's on it's way back.
Thanks.
Eric_Shea
post Aug 26 2008, 08:26 PM
PMB Performance
Very sorry about that. It's hard to understand... everything goes in as planned/normal. (IMG:style_emoticons/default/confused24.gif)
You should see it back Monday/Tuesday.
monkeyboy
post Aug 26 2008, 08:36 PM
Thanks. I have a few other things I can get done this weekend. No worries.
- Lo-Fi Version Time is now: 5th January 2025 - 03:43 AM
