Chevota79 |
Member ![]() ![]() Group: Members Posts: 83 Joined: 11-September 07 From: Rocklin, CA Member No.: 8,113 Region Association: None ![]() |
I just went and looked at a really solid '72, but the only problem is the guy swears up and down that the engine is a 2.0L (IMG:style_emoticons/default/WTF.gif) . I know they only offered 72-4's with 1.7 L. Is there and easy way to identify exactly what motor is in there so i can prove hime wrong and bring the price down a bit?
VIN # 4722920972 Pics would Help. I am pretty new. Josh |
Cap'n Krusty |
Engine number? Number of bolts attaching the intake manifold to each head? Throttle body horizontal or vertical? Air cleaner housing rectangular or round?
The Cap'n |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,597 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
A 2.0 liter motor will have the following items to look for.
Engine serial number is on the case just in front of the oil filler. The heads have three studs for the intake tubes. The plugs are facing the side of the motor, not upright. The 1.7 has the following items. Engine serial number is on the top of the case under the intake plenum. The heads have four studs for the intake tubes The plugs are facing up and angled front and back. The FI may have been changed. If not The 2.0 liter has a center throttle body aimed at the sky with a large rectangular air filter box. The 1.7 has a throttle body facing the drivers side rear. The air filter housing in roundish... Rich |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
The 2.0 liter has a center throttle body aimed at the sky with a large rectangular air filter box. a 73 2.0 air filter is round (but unlikely anyway). i would check the engine #'s over the just the 3 stud heads as it could be a bus 2.0... but definately note it's got the wrong heads then |
Joe Bob |
Retired admin, banned a few times ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None ![]() |
When I used to buy every 914 in So Cal was stood still...I couldn't tell ya how many weenies swore they had a 2.0.
3 bolt heads...yes, 4 bolts...."Oh it has a big bore kit on it"...... (IMG:style_emoticons/default/sheeplove.gif) |
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,553 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
a 73 2.0 air filter is round (but unlikely anyway). Round? (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) ![]() |
orange914 |
a 73 2.0 air filter is round (but unlikely anyway). Round? (IMG:style_emoticons/default/confused24.gif) i've not seen it in person but had just run across info/picture for the second time the other day. is this incorect? (IMG:style_emoticons/default/confused24.gif) any 73 2.0 owners? |
r_towle |
73 1.7 had a round filter box...I have one BUT I cant find an air filter for it....(IMG:style_emoticons/default/laugh.gif)
Rich |
orange914 |
3 bolt heads...yes, 4 bolts...."Oh it has a big bore kit on it"...... (IMG:style_emoticons/default/sheeplove.gif) 2.0hhhhhhh, i've been had (IMG:style_emoticons/default/beerchug.gif) |
markb |
914less :( ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California ![]() ![]() |
73 1.7 had a round filter box...I have one BUT I cant find an air filter for it....(IMG:style_emoticons/default/laugh.gif) Rich Check with Cap'n Krusty. He has the part # for a replacement filter. |
r_towle |
BTDT and more.
Capn told me to just put the oil bath filter back on...I did. Rich |
Lo-Fi Version | Time is now: 20th June 2024 - 05:40 AM |
