justdrive914 |
Member ![]() ![]() Group: Members Posts: 88 Joined: 31-July 08 From: Asheville, NC Member No.: 9,374 Region Association: South East States ![]() |
Okay went out to crank up my 1.7 today, and I wont crank, everyonce in a while it'll hit for justa second and die asap It was running perfect the other day like two or three days ago and im in asheville NC and it got down to like 30F last night and I'm wondering if the are any little things that could make it no crank cause its cold?
On my old 1.7 something happened to relay board and when it got cold I'd have to heat it up with a heater then in like 5 mins. It would crank got a different board and it cranked right up. I dont think this is the problem this time Any ideas would help thanks, andrew (IMG:style_emoticons/default/headbang.gif) |
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
Check the easy stuff like the ground strap and clean up your battery connections.
r_towle |
Test your battery to see if its full of water...and holds a full charge. Grounds need to be cleaned yearly. Battery posts need to be cleaned every three months or so. Rich |
jfort |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,137 Joined: 5-May 03 From: Findlay, OH Member No.: 652 Region Association: Upper MidWest ![]() ![]() |
I read the number once. Can't remember, except that it was amazing. When it gets cold, batteries lose much of their potency.
Lo-Fi Version | Time is now: 26th June 2024 - 02:38 AM |
