Losing oil, out of hole near cyclingder three |
turnaround89 |
Oct 20 2008, 04:44 PM
Senior Member Group: Members Posts: 671 Joined: 17-May 08 From: Rockford, Illinois Member No.: 9,067 Region Association: Upper MidWest |
Everytime i drive my car, there is always a little pool of oil that collects behind a little hole by cylinder 3, the oil collects on top of the cooling tins in the back corner of the car. The hole is next to the nut that holds the intake on, its about .5inch diameter or smaller(didn't measure it just guessing) What can i do to stop this oil issue? I also noticed this same hole is on the opposite side of the engine but instead of being behind the intake it is in front of the intake by cylinder 2, no oil comes out of that hole. Maybe the oil isn't coming out of the holes but somewhere else. All i know is that oil collects by cylinder 3 on top of the cooling tins. thanks everybody!! help my car not spew oil, my dad hates oil spots when i pull into the driveway
southernmost914 |
Oct 20 2008, 04:49 PM
KEY WEST/HAVANA Tunnel Authority Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States |
Sounds like your missing your rocker/head vent hoses. You have carbs , don't you? Show us a picture. (IMG:style_emoticons/default/unsure.gif)
Steve |
turnaround89 |
Oct 20 2008, 04:55 PM
yes, the PO sold the orig 2.0 that was in the car and put a 1.8L carbed engine in. I will get a pic as soon as im done writing my paper for a humanities class. give me like 10 minutes
Doug Leggins |
Oct 20 2008, 04:56 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I have had oil in the same place. My issue turned out to be a leaking valve cover gasket.
jsayre914 |
Oct 20 2008, 04:59 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
what kinda oil are you using?? I had the same problem pool in the rear tin, I changed to the cheapest 20-50 motoroil and added a can of purple stuff. I think it was called " compression in a can" from flaps. I wiped the tin clean, and never saw the puddle again. (IMG:style_emoticons/default/smile.gif)
turnaround89 |
Oct 20 2008, 05:03 PM
I don't know what oil is in the car at the moment, i have only drove it about 10 miles max since ive had it. An oil change wouldn't hurt. However, i have never seen a 20w-50 oil at autozone or any autoparts store where i live.
I think i might have extra valve cover gaskets if i need to put those on i will, no problem there. The picture will be here in just a minute, gotta print this paper! |
southernmost914 |
Oct 20 2008, 05:09 PM
I'm pretty sure your missing a crankcase breather system.
like this or better, 3 hoses. The blue one that you see and one to each head wich are not in view. Steve |
turnaround89 |
Oct 20 2008, 05:25 PM
Would the ones from the heads go into the breather system, or somewhere else?
Here is the pictures i promised (IMG:http://i268.photobucket.com/albums/jj2/aheimer89/SG107988.jpg) (IMG:http://i268.photobucket.com/albums/jj2/aheimer89/SG107989.jpg) (IMG:http://i268.photobucket.com/albums/jj2/aheimer89/SG107990.jpg) |
southernmost914 |
Oct 20 2008, 05:29 PM
Those should have hoses going to a aftermarket breather system.
Steve |
turnaround89 |
Oct 20 2008, 05:30 PM
was there ever a stock breather system? Where can i get the breather system? thanks
r_towle |
Oct 20 2008, 05:34 PM
Custom Member Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
You have two choices.
You can go get two brass 90 degree barbed fittings at the local hardware store (one side is barbed the other side is threaded) Drill two holes, one on the top of each air filter cover and then using the fitting, attach that fitting to the top of the intake and run a hose to each head breather (there is one on the other side at the front of the head) Second option is look up CBperformance.com and you can buy an aftermarket breather from them. The aftermarket breather system has one drawback...it allows oil mist to blow out into the engine bay and eventually you get everything covered...its a light mist. Rich |
turnaround89 |
Oct 20 2008, 05:52 PM
Do i have to put the fitting onto the top of the air filter cover or can i run them at the bottom in the corners? There is a white fitting like you mentioned underneath the carb already that the hose from the oil inlet goes to that fitting, the hose im talking about is the light blue one in southernmost914 picture, his goes to the aftermarket breather and mines goes to the fitting underneath the carb. What about like a three way fitting so that all 3 lines collect into one hole or should i just stick with all three lines having seperate fittings? Thanks for the help, im off to the hardware store.
southernmost914 |
Oct 20 2008, 05:56 PM
Do i have to put the fitting onto the top of the air filter cover or can i run them at the bottom in the corners? There is a white fitting like you mentioned underneath the carb already that the hose from the oil inlet goes to that fitting, the hose im talking about is the light blue one in southernmost914 picture, his goes to the aftermarket breather and mines goes to the fitting underneath the carb. What about like a three way fitting so that all 3 lines collect into one hole or should i just stick with all three lines having seperate fittings? Thanks for the help, im off to the hardware store. That will work! Both ways. Steve |
Grelber |
Oct 20 2008, 06:11 PM
Insert favorite Don Rickles joke here. Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region |
I had a breather problem too, and my engine guy said not to run the breather hoses into the carbs, because you don't want to put that oil back into the intake system and gunk it up.
I put a WTB ad here on the board, and had a great deal on an Empi tank within a few hours. The tank has a foam filter inside that I clean out every few months, so it doesn't put the oil mist out onto the engine. |
SirAndy |
Oct 20 2008, 07:09 PM
Resident German Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
On a FI motor, those each have a hose going to the airfilter.
On carbed motors, you can use a aftermarket catch can setup that will drain back into the oil filler neck. The one i had on my 2056 was from CB performance. (IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
turnaround89 |
Oct 20 2008, 08:10 PM
SirAndy, on your setup your middle line that goes to the filler tank goes into the hole there. I think the hole on my filler tank is on the opposite side than yours. Just out of curioity, how does the catch can thing eliminate the oil issue? Why will the oil go into the catch can rather than onto my cooling tins?
Or in the way i am going mine, why will running these lines into the underside of the air filter solve the problem? Thanks everybody!!! |
SirAndy |
Oct 20 2008, 08:42 PM
Why will the oil go into the catch can rather than onto my cooling tins? Beacuse right now, those ports are open straight into your valve covers. In fact, if i were you, i'd be really concerned about debris falling into your cylinder heads and getting inbetween the valve springs or rocker arms ... (IMG:style_emoticons/default/stirthepot.gif) On lower RPM, those holes suck in Air, but at higher RPMs, they will spray oil out straight from your valve assembly. If you attach a hose to each and route them to a high mounted catch system, the oil vapors will accumulate in the catch can and drain back into the oil filler after you turn off the motor. On a FI car, those oil vapors simply get burned by venting them into the airfilter. Either way is better than leaving those ports open. Like i said, i'd be more concerned about "stuff" falling into the ports than a little bit of oil coming out of them. And before you ask, no, just plugging them off is not a good idea either. They're part of the crank case ventilation system and should not be simply plugged. (IMG:style_emoticons/default/shades.gif) Andy |
turnaround89 |
Oct 20 2008, 09:27 PM
Thanks everybody, 2moro i will drill the other hole in the underside of the air filter and get everything straightened out, if this doesn't work, i will purchase a breather for the car on thursday = payday (IMG:style_emoticons/default/biggrin.gif) )!!!
scottb |
Oct 21 2008, 04:57 AM
who wants a PEZ?! Group: Members Posts: 1,993 Joined: 27-December 02 From: south-(not north)-wick, MA Member No.: 32 Region Association: North East States |
a look in the vendor section shows our very own chris foley making these breather systems designed specifically for the 914...
914 breather cans i have one and am very pleased. cheers, scott |
turnaround89 |
Oct 22 2008, 12:58 AM
Just want to say thanks to everybody's help on my oil issue. I ran the lines to the brass fittings and vented it into the carb, works really well and no more oil on the cooling tins. Thanks again, everybody!!!!
Lo-Fi Version | Time is now: 26th June 2024 - 05:04 AM |
