LarryR |
Senior Member ![]() ![]() ![]() Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 ![]() |
I have been looking at different bulk head mounts and I am leaning towards the patrick motorsports mounts. I figured I might as well throw the question out there to see what others have used.
Right now the reasons I am leaning towards the PM mount is because it has the mounts further apart, seems to have a more race oriented poly mount, and a good quality construction. The negative is that it is about 200 more than the other mount I am looking at but I figure worth it for a fairly mission critical part. Here is the PM mount: ![]() Here is the other one I am looking at: ![]() All feedback both positive and negative are appreciated. Larry |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,643 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
you will get a lot of feed back that patrick's stuff is no good
I think the motor bars often did break I have the patrick bulkhead mount its good for racing not good for originality I can drop/tip my motor more easily with this mount I once dropped it 2x in one day at a track and still finished the day out on track..... good for racing if you factor in serviceability. (not sure it adds any benefit in structure) brant |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Two words. "Rich Johnson". Buy his mount. The Cap'n
Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
you will get a lot of feed back that patrick's stuff is no good I think the motor bars often did break brant I think that the motor bars that were of concern were the ones that mount to the stock four locations. I don't think that you can use the stock style heat exchagers with the PMS mount. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
Two words. "Rich Johnson". Buy his mount. The Cap'n (IMG:style_emoticons/default/agree.gif) The patrick mount doesn't nearly have the same surface area to weld to the firewall. And i certainly wouldn't just bolt it on anyways. The racers like it because it's easy to drop the engine and transmission just enough to get to the valves. The RJ mount is much more "sturdy" and i use it with 911 sport motor mounts on my 3.6L ... (IMG:style_emoticons/default/w00t.gif) Andy Here's a pic of mine with a nice welded bead around it: Attached image(s) ![]() |
LarryR |
Thanks for all of the responses. It looks like the Richard Johnson mount is the way to go. Glad I posted here first. Thanks, Larry
Bucci |
Bucci ![]() ![]() Group: Members Posts: 106 Joined: 11-August 08 From: Carlsbad,Ca Member No.: 9,407 Region Association: Southern California ![]() ![]() |
Thanks for all of the responses. It looks like the Richard Johnson mount is the way to go. Glad I posted here first. Thanks, Larry Larry, there is one more mount that I know of. It is built by Randy Beck and is a bolt-in to a four cylinder car with stock motor mounts. No... Cutting, drilling, welding etc.... Please respond and I will send out a picture I have one of these bars for my six conversion and has worked well for over 12 years! Best Marc- phone number 619-726-9012 |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
I have to say I really like the Patrick mount. It was easy to install, I did it in a day while I was swaping enigines. Pulled the engine, tacked and welded it up, and when I was ready to put the other engine in it was ready. Didn't need to pull the wiring harness or lines or anything. Plus, there is more surface area than a stock six mount and they use these in cars with over 300hp.
On the other hand, the Rich Johnson mount it a very nice mount as well. There is more to installing it but the overall quality is great. |
PeeGreen 914 |
Thanks for all of the responses. It looks like the Richard Johnson mount is the way to go. Glad I posted here first. Thanks, Larry Larry, there is one more mount that I know of. It is built by Randy Beck and is a bolt-in to a four cylinder car with stock motor mounts. No... Cutting, drilling, welding etc.... Please respond and I will send out a picture I have one of these bars for my six conversion and has worked well for over 12 years! Best Marc- phone number 619-726-9012 I had this mount on my car before I did the Patrick mount and I wouldn't sugest doing it. It is just the cheap way of getting a six in. If you are doing any kind of racing it is unsafe and very heavy. |
Root_Werks |
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,341 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest ![]() ![]() |
Either of the 2 mounts you first pictured are great and will work. I really like the RJ mounts and have installed bunches of them. I personally preffer the Maddog mounts which is pretty much the same as an RJ mount which was pretty much the same as the old Velios mounts. The maddog mount you have to pull the wirring loom through it rather than cover it up. Looks more factory, more work, but if you ever have to get to wires for any reason, you'd be happy you put in a maddog mount. Those are my favorite.
LarryR |
(IMG:style_emoticons/default/beerchug.gif) I guess I am now torn between the 2 b/c being able to do a slight drop for a valve adjust is very appealing. However, stability is nice but it seems the PM bulk head mount was never a problem but the one that mounted to the oe positions was but is NLA. the RJ mount is actually more expensive if purchased from Pelican by 150 but he seems to post on other forums for less than the PM price. Decisions, decisions...
Lou W |
Grngoat |
Lurker Member ![]() ![]() Group: Members Posts: 158 Joined: 17-October 04 From: Fort Worth, TX Member No.: 2,967 Region Association: Southwest Region ![]() |
That is the Rich Johnson mount. A914guy@aol.com is his e-mail. So you'd be buying it directly from him cheaper than through Pelican. Funny thing, that is my car in the second picture. The one of the freshly painted mounted. All the other pics are a different car. I forgot that I sent him that pic. Cool. |
LarryR |
That is the Rich Johnson mount. A914guy@aol.com is his e-mail. So you'd be buying it directly from him cheaper than through Pelican. Funny thing, that is my car in the second picture. The one of the freshly painted mounted. All the other pics are a different car. I forgot that I sent him that pic. Cool. cool I bought that one. 305 bucks I figure good quality and price.. Thanks again for all the feedback. |
LarryR |
I also talked with Rich for about 30 minutes after I bought it ... super nice guy. I would recommend just contacting him direct for the bulk head mounts.
PeeGreen 914 |
Richard Casto |
Blue Sky Motorsports, LLC ![]() ![]() ![]() Group: Members Posts: 1,465 Joined: 2-August 05 From: Durham, NC Member No.: 4,523 Region Association: South East States ![]() |
I would second Rich Johnson. I am in the middle of purchasing a number of things from him (including his bulkhead mount) and he is very helpful and a nice guy.
thesey914 |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 ![]() ![]() |
I have the RJ mount. the only criticism i have is it's very fiddly to actually bolt your engine in. Unless i was doing it wrongly, you need 2 people, one to wrench leaning in through under the engine lid and you need to be under the car holding the other end of the bolts from turning.
and the engine is a nightmare to install with the tinware fitted and trying to clear the protruding mount -guess this would be the same for the PMS mount also |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
If I didn't make my own, I would also suggest the RJ mount.
Attached image(s) ![]() ![]() |
SirAndy |
If I didn't make my own, I would also suggest the RJ mount. Solid mount? (IMG:style_emoticons/default/huh.gif) Andy |
Lo-Fi Version | Time is now: 26th June 2024 - 05:47 AM |
