GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
I have my B-inlaws 72 in my garage for a while. I went to move it over to another bay last night and noticed that with the lights off the turnsignal lights on the tach were on kind of dim. Not blinking, just dimly lit. Only other light on was the fasten seat belt light. I turn the lights on and everything works like they should. I also noticed the voltmeter was showing just under 12volts. I didn't have time to troubleshoot it, but just looking for your thoughts on what to check. I know to check and clean all grounding points, anything else?
Danke |
orange914 |
http://5starmediaworks.com/index.html ![]() ![]() ![]() ![]() Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California ![]() |
it sure sounds like a weak ground but whats weird is they brighten with additional load (turning lights on). does the turn signals some how gain a additional ground with the headlights on?
i'd check for a voltage drop at the turn signals both before and after headlights turned on. i was told years ago by a shop teacher that a majority of electrical problems are somehow ground related, and i've really found that true. redundant grounds are a 914's best friend (IMG:style_emoticons/default/biggrin.gif) mike |
southernmost914 |
KEY WEST/HAVANA Tunnel Authority ![]() ![]() Group: Members Posts: 338 Joined: 16-October 07 From: Key West/ St. Augie, Fl USA Member No.: 8,234 Region Association: South East States ![]() ![]() |
I had the same problem. 70-74 models had seperate L/R indicater lights. I had a dim light all the time and both the idicator lights would light at the same time when signaling. Replaced the turn signal relay and all was solved. 12v reading on the console gauge is pretty much normal because it is actualy monitoring the brake cicuit, but clean the ground to the gauge just in case. (IMG:style_emoticons/default/bye1.gif)
Steve |
Lo-Fi Version | Time is now: 24th June 2024 - 06:08 AM |
