Todd Enlund |
Resident Photoshop Guru ![]() ![]() ![]() ![]() Group: Members Posts: 3,251 Joined: 24-August 07 From: Laurelhurst (Portland), Oregon Member No.: 8,032 Region Association: Pacific Northwest ![]() |
Am I correct in my assumption that this lovely weld bead was added by the DAPO? And that it renders my pedal cluster un-rebuildable?
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Stick a hacksaw in here and cut it off. It will take about 5 minutes. Then you can get a new shaft and pedal.
![]() I may have a pedal for you but I think my shafts have wallowed holes on the end. I may have a decent pedal assembly for you if you want it... bronze bushings etc. Needs a paint job. |
PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Stick a hacksaw in here and cut it off. It will take about 5 minutes. Then you can get a new shaft and pedal. ![]() I may have a pedal for you but I think my shafts have wallowed holes on the end. I may have a decent pedal assembly for you if you want it... bronze bushings etc. Needs a paint job. I have one you can have the next time you're up Todd. |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,440 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Just grind the weld off. the pin is probably sheered ,the rest is fine.
Lo-Fi Version | Time is now: 25th June 2024 - 07:56 PM |
