KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
I snapped the top off of an exhaust stud a few days ago. There is thread left, but not too much. I have tried to double-nut it out, but there isn't enough engagement to get 2 nuts lined up and tight.
I tried some red lock-tite, and let it sit on a nut on the stud, but it came right off. I need some tips or tricks to getting that stud out. TIA |
dkjens |
Member ![]() ![]() Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None ![]() |
Is the engine still in the car and runs? If so, run it and get the head warm, try to get a grip with a wise grip. If engine is out, heat that area of the head with a heat gun. If the stud is really stuck in there and liquid wrench isn't helping, I don't know what else than heat would let the aluminum let go of the stud.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
On a stud that I had a bitch of a time getting out, the guy that "won" used oxy/acc torch on the boss around the stud, and then cooled the stud with a wet rag and turned it out with a massive set of vice grips.
Or, you could try welding the nut on to the stud intead of double nutting. Zach |
jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
I had to remove some where double nutting didn't work (not enough). I went down to autozone and purchased some metric stud removers. They look like sockets...grip the stud and lock on tight while you are loosening. Think I paid 20 bucks for a set of 4.
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,733 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
Heat is good. Then take a hammer and a punch and tap on it. Also try to tighten it a little, just to get it moving, then loosen, then tighten and loosen...hopefully it will move more and moor each time. Don't forget to threatin it with curse words.
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,680 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
I have felt your pain. I put a nut on mine and had a buddy weld them together and it backed out no problem. With the right tools not so bad, but I spent about 3-4 days trying myself first. SHould have just called my buddy instead of wasting 6 hours.
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
One trick to try is Heat and paraffin wax. The wax can wick down the imbedded stud and help in removal,
or welding the nut on the stud has worked for me, but let the nut cool enough to hold but still leaving the stud hot as hell, this method has work when others failed. |
dinomium |
Git on a chair son, all the good stuff is goin over yer head! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest ![]() ![]() |
I now vote for the weld a bolt over the AutoZone extractor kit. Boss is now broken; It was probably weak already, but when I used the exstractor, it cracked the boss on the head and now it is more than half GONE! Doh! Now my exhaust swap has become and engine and tranny swap! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) |
Gint |
Mike Ginter ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,086 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains ![]() ![]() |
Drill, tap, timesert.
Search 914world for "timesert" http://www.timesert.com/ [url=http://www.timesert.com/html/install.html]Timesert demo video] Probably won't work for Dino since the boss is trashed, but I like these for blind exhaust stud holes if the boss in intact. |
KaptKaos |
I have tapped and used step down studs when a hole is stripped. I am running 2 now.
I am going to try and find a stud extractor today. I will heat the boss with my little propane torch to help it along. Any other hints? I see you lurking here Len. Help me out Bro!! |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
Those ex studs are a real PITA. Sometimes even old ones that look good turn out to be brittle. Early on I would leave the original studs in when servicing heads for customers that wanted to save a buck. If they looked okay and the guy didn't want to spend the money... After to many broke during reassembly, I quit offering the stud replacement as an option and made it standard.
I remove the old ones with the head mounted in a fixture on one of my Bridgeports. And let me tell you, even in that ideal postiion with heat and PB Blaster some of them just flat won't come out! (IMG:style_emoticons/default/headbang.gif) Drilling down the middle of the stud is tricky but doable in the mill. Laying on your back under the car and trying to shoot down the middle of the old stud with a hand drill and a left hand drill bit... some really skilled/lucky people have pulled it off. And some really skilled/unlucky people have shot into the combusiton chamber! The row of studs that are closer to the crankshaft are the ones that cut right under the combustion chambers. These are the ones you really have to be careful with. If the bit drifts off center it can and often does run right into the chamber. I have seen many heads that came in for this secondary repair after a DIY nightmare. In one case a fellow working on one of the other studs actually drilled into the valve guide and didn't stop until he hit a valve! I sympathize with anyone attempting this while laying under the car. Heat, patience, PB Blaster and prayer! Good luck, and wear eye protection! |
KaptKaos |
PBlast is tough since the car is up on ramps. I'll keep shooting it in.
I am in no rush, so I am hoping a little torque and patience will win out. More to follow. Thanks for the advce! |
KaptKaos |
Anyone in SoCal have something like this:
http://www.sears.com/shc/s/p_10153_12605_0...00P?vName=Tools Sears doesn't stock them locally, so that sucks. |
dinomium |
Anyone in SoCal have something like this: http://www.sears.com/shc/s/p_10153_12605_0...00P?vName=Tools Sears doesn't stock them locally, so that sucks. that is what I just used to explode my head boss and my HEAD, BOSS! (IMG:style_emoticons/default/chair.gif) (to myself!) |
Wilhelm |
Member ![]() ![]() Group: Members Posts: 408 Joined: 7-September 07 From: Hooterville, OR Member No.: 8,088 Region Association: None ![]() |
KaptKaos |
How do you get the paraffin up there when the motor is in the car????
KaptKaos |
The plot thickens.
Stevo lent me his MIG welder. Having not welded since high school, I was making some practice welds. Well, the wire stopped feeding. It seems to make it to the handle, then stops. Any hints? |
FourBlades |
From Wreck to Rockin ![]() ![]() ![]() ![]() Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States ![]() ![]() |
You probably have spatter sticking the wire to the nozzle. Try unscrewing the nozzle or chipping any junk off the end... Turn it off first, of course, and wear gloves because they get very hot (obviously)... |
Wilhelm |
Unscrew the copper tip of the miggy where the wire feeds through to make sure the wire didn't weld itself into the tip. Sometimes you have to unscrew the entire tip and its holder from the end of the mig to get the wire through as this is a typical area for the wire to hang up on. Also check the pinch roller that feeds wire into the cable from the spool to make sure you didn't get a wire kink or a birds nest going on here.
If you heat the head and stud enough, take the torch away and jamb an unlit candle at base of the stud and capillary action will wick molten paraffin into the threads, just like soldering copper pipe. |
24/7 911 |
Newbie ![]() Group: Members Posts: 21 Joined: 28-August 08 From: Koblenz, Germany Member No.: 9,473 Region Association: Germany ![]() |
Hi,
some of the guys over here had good results with Würth "Rost off ice" just for getting the stud loose. But I don't know if you can get it there Marc |
Lo-Fi Version | Time is now: 25th June 2024 - 04:54 PM |
