Txgasser |
Newbie ![]() Group: Members Posts: 22 Joined: 12-November 08 Member No.: 9,743 Region Association: None ![]() |
Has anyone done a single Weber/Dell turbo blow thru system on a 1.8 or 2.0,914-4? (IMG:style_emoticons/default/idea.gif)
Johnny! tx-gasser@sbcglobal.net |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Just gotta say it!~ You can't turbo a teen! (IMG:style_emoticons/default/biggrin.gif)
Mark Henry |
That's over with.....it's been done, a member here used to make a kit in the late 70's -early 80's, with carb is very old school. Randy has/had one, don't know if he ever got it going.
Programmable EFI would be the much better way to do it, use the search function. |
dkjens |
Member ![]() ![]() Group: Members Posts: 159 Joined: 24-November 08 From: Pasadena, CA Member No.: 9,785 Region Association: None ![]() |
My neighbor has a sandrail with an approximately 2.1 l type 1 engine with turbo and single suck through side-draft weber. He loves that engine, low end torque and high end power and all the time you don't have your foot in it, it's a docile low compression engine.
Mark Henry |
My neighbor has a sandrail with an approximately 2.1 l type 1 engine with turbo and single suck through side-draft weber. He loves that engine, low end torque and high end power and all the time you don't have your foot in it, it's a docile low compression engine. Type 1 is easy to do...it doesn't have the head sealing issues of a T4. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,598 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
My neighbor has a sandrail with an approximately 2.1 l type 1 engine with turbo and single suck through side-draft weber. He loves that engine, low end torque and high end power and all the time you don't have your foot in it, it's a docile low compression engine. Type 1 is easy to do...it doesn't have the head sealing issues of a T4. I'll bite. Why does a type 1 seal better than a type 4 head? Rich |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
My neighbor has a sandrail with an approximately 2.1 l type 1 engine with turbo and single suck through side-draft weber. He loves that engine, low end torque and high end power and all the time you don't have your foot in it, it's a docile low compression engine. Type 1 is easy to do...it doesn't have the head sealing issues of a T4. I'll bite. Why does a type 1 seal better than a type 4 head? Rich Was wondering that myself. Zach |
Mark Henry |
The jug holes are closer together as are the studs. The studs are also evenly spaced. They have way less head sealing issues.
Many T1 turbo's out there. Just realized he said single blow thru, so my bad as it's draw through is the common carb set up. CB does make a dual carb blow thru for the T1, but I've never seen a T4. |
Txgasser |
Oh Well, Back to the drawing board!
VaccaRabite |
Don't give up so easily. There are a few turbo T4 motors out there. One of them is on this board, with a single carb setup.
From what I have read the 1.7 takes it the best of the different 914 engines. Search around, you will find them. Do it, and document everything! Zach |
Lo-Fi Version | Time is now: 25th June 2024 - 05:27 PM |
