nycchef |
mechanical moron ![]() ![]() ![]() Group: Members Posts: 952 Joined: 28-November 05 From: new york city n.y. Member No.: 5,202 Region Association: None ![]() |
well it's that time of the year in the northeast. time to put my signal orange money pit back on the road. last we heard i had switched my 1.7 d-jet for a 2.0 w/ dual webers. i need to get new battery cables and then i need to figure out how to hook them up. you know, + to starter - to..... coil connects to.... well thats all i got. where can i buy a good set of cables and anyone have a diagram of what goes where?
So.Cal.914 |
"...And it has a front trunk too." ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,588 Joined: 15-February 04 From: Low Desert, CA./ Hills of N.J. Member No.: 1,658 Region Association: None ![]() |
Ground bolts to the tub close to stock battery location. It's a lug welded to the tub.
Positive goes to the starter. |
r_towle |
Im not sure how your car is wired, but the stock positive lead needs to have three large red leads attached to it also..
Call AA for the right positive lead...its not a NAPA item. The ground can be a NAPA item. Rich |
nycchef |
Im not sure how your car is wired, but the stock positive lead needs to have three large red leads attached to it also.. Call AA for the right positive lead...its not a NAPA item. The ground can be a NAPA item. Rich hey rich how have you been. will check out aa where do the 3 leads go? |
r_towle |
Ignition switch...fuse panel...etc...
Been good....got mine out today...nananananana I have snows on it and its all set to go...alot more fun than any other car Ihave... Car washes get visited more often with the 914 also. Rich |
Lo-Fi Version | Time is now: 26th June 2024 - 04:44 AM |
