6freak |
MR.C ![]() ![]() ![]() ![]() Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest ![]() |
![]() Not a real good pix but you can see the rust has not migrated to far |
6freak |
![]() not 2 bad..but i need to get on it ..so i am |
6freak |
![]() Looks ok from the inside |
6freak |
![]() It will be done in about two weeks ...more pix to come soon...still learning how to post pix and run this damn puter so bear with me |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
![]() Not a real good pix but you can see the rust has not migrated to far I don't see any rust??? *EDIT* looking at the other pics, looks like your problem is really tiny. Spray a lot of Metal Ready down there and be done with it. Unless there is more then it looks from here, its not worth cutting into decent paint over. Zach |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,825 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Be thankful. Its funny that the spot formed in that one location and it didn't originate in the sale panel and just bust thru there. I thought for sure you were going to need to fix the tranisition between the sail and the body where the little holes for the trim are drilled. Actually, now that I look at the photo again, your looking into the little tube that connects the door jam to the inside of the car. You can't see the rust growth on the back side from there. Can you get a light inside the rear quarter panel above where the oil tank is mounted and take a good look?
6freak |
well it went to the shop Thursday.The paints ground down to bare metal now and the hole will be leaded in,the foam stuff removed and some por15 added under the finder(or wax)where the welds are.alldents in the rear deck lid fixed and she`ll be brand new again.I couldnt just let it go and get worse that would have not been fair to my car when she brings me so much fun.But i will say it cost me my 2.2 hotrod motor
6freak |
Im going to clean out all that foam stuff and take a good hard look in that area for sure ..I dont think i will be able to save the original sail panel though if i have to go up in that area for repairs (IMG:style_emoticons/default/headbang.gif)
VaccaRabite |
That foam is EVIL stuff. It always get rusty under it. Search and destroy, says I.
Mine had a little rust there as well, very localized. I think that many 914s get a little water dribble in from the chrome strip. Metal ready is the por15 family rust neutralizer. I sprayed (and prayed) it in every hidden channel that I could find on my car, until it dribbled out. Then I sprayed in some more. Zach |
6freak |
if it was just water from the chrome strip it would dry but its dirt and debris from the tires and then add the water that you cant get out..walla it stay wet and then rust`s ..we all know this ....Man what a BITCH...Im learning more about this wax stuff its kinda cool stuff.Because por15 wont stick to clean metal survice and it will I will report back soon (IMG:style_emoticons/default/smile.gif) more pix soon 2
6freak |
PanelBilly |
I still think the important photo is the one from the inside of the car. What's going on other side of the metal is important.
Solo914 |
Member ![]() ![]() Group: Members Posts: 266 Joined: 6-March 06 From: Redmond, WA Member No.: 5,678 Region Association: None ![]() |
I am feeling your pain right now. I had my car painted 2 years ago and there was no rust in that space(on the passenger side) on my car before it was painted. Fast forward to today, there is about a dime sized rust bubble starting. Best I can tell is that when I refastened that sail chrome during assembly i didn't treat the backside of that hole well enough and water got in there and did its thing. I think I am going to just treat that spot for now(not paint the hole panel yet). Basically, dig out rust carefully, treat front and back and then spot fill/airbrush and then wetsand and polish. If it looks good from 5 feet it will be good enough for me for awhile. Kyle |
6freak |
![]() that damn foam stuff has got to go ..you can see it through the hole the spot where it looked like the paint was just a little bubbled got worse after the sanding started so now theres two pencil size holes ... (IMG:style_emoticons/default/headbang.gif) man i hope i didnt open a can of worms |
6freak |
![]() Little dirt and oil down in the corner but this area is fine ..its only that one spot |
6freak |
![]() This is how it all started ..sorry for way the pix were not in order |
6freak |
6freak |
![]() Last one for a few days ...go`n make to the shop tonite to see what the damage is...wish me luck.................WHOOPS NO PIX |
PanelBilly |
Is this a close up of the hole?
Solo914 |
Lo-Fi Version | Time is now: 30th June 2024 - 11:40 PM |
